Question about Fisher and Paykel Dryers
My fisher & pakyel dryer de45f56e will run for a while then stops and wont run again until the door is open and shut andthere seems to be to much moisture around the door as well and also beeps three time when you push the start button
astruttman
  • 45 Answers
SOURCE: Turning the beep off?
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Jan 11, 2009
SOURCE: Fisher & Paykel DE08 Dryer sensor
My guess is your PC Board (PCB) is shot and needs to be replaced. From the manual: The PCB measures moisture across the sensing bars on the front duct assemby (it is possible, but unlikely that the sensing bars have lint over them which may be causing a problem). As the clothes slide past the bars the PCB reads the current across the bars. When the clothes are dry the current ceases so the PCB advances the timer. There should be a min of 1 M ohm across the bars when dry. The resistance should be lower when mositure tracks across the bars. To test the bars check the resistance when dry, then wet your finger and place it across the bars and check for resistance. Again...it is very unlikely the bars are the problem. More likely it is the PCB. Part Number WE1M418 for the DE09 (similar to the DE08, but check to make sure with your local appliance parts person). How to replace the PCB: Open the console; unscrew and remove the PCB cover; disconnect the PCB connector; unclip PCB from its holding clips. Reassembly is the reverse procedure. NOTE: The PCB is NOT, repeat NOT, the timer!! It is located on the inside of the console on the left hand side of the instrument cluster
Posted on Mar 07, 2009
SOURCE: dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Posted on Apr 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 08, 2009
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
I need operating instructions for Dryer Model No. DE45F56E which we bought new last October and have not use - but now I canot find operating instructions could you please email thanks
was using dryer, paused the cycle and took out clothes, now the dryer wont work and every time i press the start button it beeps at me three times really fast. there is a red flashing light left of the lock button.what is wrong and how do i fix this????
Jul 20, 2011 | Fisher and Paykel Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Won't shut off unless the door is opened
Usually the only thing that will stop the dryer is to open the door or turn the timer to the off position.
Nov 24, 2009 | Dryers
Machine over flows and does not stop filling
The part that the two hoses are connected to is an electric valve that shuts the water off when the machine is full. It seems like it is time to replace it.
Nov 07, 2009 | Fisher Washing Machines
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
135 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
