Question about Samsung S3600 Cell Phone
PHONE LOCK - Samsung S3600 Cell Phone
How unlock my phone
What kind of phone lock code do you need?Security lock or network lock
Security lock means try default codes like 12345,00000
If it's network lock,you can unlock your phone by network unlock code.If you need an unlock code visit
WickedUnlock.com
Jun 03, 2014 | Sony Ericsson Walkman W205 Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Nov 03, 2010 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
How to lock the keys
If it is a flip phone, most flip phones dont offer the ability to lock the keys because they are thinking there isn't a need for that since the keys are hidden by the top of the phone, if it is a candybar phone usually the menu key and the * (star) key are used to lock and unlock your phones, if its a smart phone there may be some options in the settings. You didnt mention what brand your phone is based on the model number sounds like a samsung. you can go to samsungs website and research the model number and usually they have information on how to do everything you need with the phone. most cell phone carriers have this info too, you may have to dig threw the website a little though
Dec 29, 2008 | Sony Ericsson Z610i Cellular Phone
My SGH-T629 came from the U.S. how can i make it capitable with the sim card in the phillipines
A. Turn on phone with full battery and non-T-Mobile SIM in place.
Allow phone to completely boot up to Wrong SIM screen. B. Enter from Wrong SIM Screen *#7465625# to confirm lock status C. Scroll through Interrogate Screen 1. Network lock - Active (this is the one you'll be deactivating)
2. Subset lock - inactive
3. SP lock - inactive
4. CP lock - inactive
5. SIM Card lock - inactive
6. Activa lock - inactive
7. Auto network lock - inactive
8. Auto subset lock - inactive
9. Auto SP lock - inactive
10. Auto CP lock - inactive
11. Auto SIM Card lock - inactive
12. Phone lock - inactive D. Push "C" button under navigation button to clear Interrogate screen back to Wrong SIM
screen E. From the Wrong SIM screen enter the following: *7465625*638*00000000*00000000# Those are two series of eight zeros. The phone will not show the zeros but will show dashes in their place. Phone may make a small tone and at the bottom of the screen it will read "Network Personalized" or perhaps "Network Already Personalized" F. Now input the following from whatever screen shows up: #7465625*638*00000000# (again this is a series of eight zeros) Phone may make small tone and will read "Network Lock Deactivated" G. Turn off phone
H. Re-start the handset and allow it to reboot.
J. Enter from Standby Screen *#7465625# to confirm lock removal status K. Scroll through Interrogate Screen 1. Network lock - inactive (note that this lock is now inactive)
That's it. Your phone is ready to accept SIM cards from just about any GSM mobile telephone service provider in the world. If you received a "wrong password" message you will need to insert a working SIM and reset the password to the default 8 zeroes "00000000". After that you may try this process again and it should work.
Dec 02, 2008 | Samsung SGH-t629 Cellular Phone
Folder lock
hi mate i wont to lock my folder lik music,pictures and videos but i dony have the program on my phone can please help me??????????????
Jun 27, 2008 | Sony Ericsson Walkman W810i Cellular Phone
As you asked
ok, so all the locks are off on the phone.
The imei code is valid no one has changed it.
Its possible that the phone has been reported stolen?
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Samsung S3600 Cell Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
