HOW DO L TAKE THE AGITATOR OFF SO THAT L CAN CHECK THERE IS NOTHING STOPPING IT TO SPIN. CURRENTLY, IT HAS STOPPED SPINNING . IT STILL FILLS WITH WATER AND DRAINS.
    Sergeant:
    Champion:
  • 218 Answers
Is the load properly balanced. Most washers will not spin if the load is heavy to one side or the other.
Posted on Mar 20, 2011
  • miriam_madda Mar 20, 2011
    washer is empty- still not spinning
  • Sid Schmidt Mar 27, 2011
    sorry this took so long the notification went to my spam folder. The next thing I would check would be the switch for the lid. if it has failed the washer will think the lid is open and hence will not spin just like if you open the door during the spin cycle it will stop.
Washer wont agitate, it starts it fills it tumbles then it stalls. no codes, no power issuse, it stops counting down and does nothing.
Hey Stan, thank you for your post!
From what you have described your Frigidaire washer will not agitate and it will stop operating. I would recommend checking to make sure the drain hoses to assure they are not too long or restricted. Since it will spin and drain on a separate cycle it could be a possible issue with the motor, control panel, or wiring harness. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help with your current issue I would suggest seeking professional assistance to provide you with an accurate diagnosis. This will help you avoid any unnecessary part purchases that may cause an inconvenience to you. I hope this information is helpful to you. -Matt
Dec 31, 2015 | Frigidaire Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Not spinning or draining, only fills and agitates
the mixing valve in the rear needs to be repaced-it controls the water flow Also sounds like the clutch of the transmision maybe be a factor if the machine doesn't spin
Jul 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
