Question about Orion STV2763 27" TV
Hi I have a orion tv and I can not figure how to get it to play a DVD player or to program a remote to turn the channels I need help
  • 84 Answers
How to hook up a DVD Player:
http://www.wikihow.com/Hook-Up-a-DVD-Player
How to program a universal remote:
http://www.ehow.com/how_9191_program-rca-universal.html
Posted on Mar 20, 2011
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Hello, we have an Orion DVD/TV combo and have no remote for it. Is there any way to play a DVD without the remote the Play button alone on the unit does not play the DVD from its menu? We live in...
You should be able to do a channel search and come across the inputs either at the upper end or the lower end of the channel search. Using the channels on the TV itself, not cable or satellite, scroll through the channels until the desired input is found. Once on the desired input open the DVD player and insert a DVD and close the drawer. The DVD should start to play automatically. When it gets to the place on the DVD to actually "play movie" press the select/enter button on the remote. As for the replacement remote I would get a universal remote. They are far fairer in price than an original replacement remote and every bit as reliable. Just make sure to take the model of your TV/DVD player with you to make sure the remote you purchase is compatible. You probably need to go no further than your local hardware store or department store. Save on the shipping too. However if you are set on getting the original remote here is a place http://www.orion.newremotecontrol.com/catalog_item.php?catnum=076R0DT090 they also sell a few generic remotes for a few dollars less.
Regards, Tony
Apr 17, 2011 | Orion TVDVD091 9 in. TV/DVD Combo
I have One For All URC-4063 remote control. How do I program it to my orion TV
Hello
The codes for Orion TV with One for all URC-3021 are
0236, 0463
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Mar 20, 2011 | One For All URC-3021 Remote Control
Orion model TV1934a - I do not have the original remote - how can I set it to play a DVD. I have generice remote that does work the TV but the input button on the remote does not work.
Try doing a auto channel search while a dvd is on and connected to the TV. An av input is usually reached to the bottom of all the channels. for example pushing the channel below channel two the next one would be AV input.
Jun 28, 2009 | Orion1934 19" TV
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Sanyo Model AVM 3659G won't recognize DVD player
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Sanyo AVM-3659S 36" TV
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
Tv codes
Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
Mar 16, 2008 | Philips Magnavox REM-350 Remote Control
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
Sep 26, 2007 | Televison & Video
Orion STV2763 27" TV Logo
162 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
