Question about Kohler Plumbing
How do kohler gp500520 balancing valve and gp71969 mixer work? and how to install them? wakaidaikon@yahoo.com
2 Suggested Answers
bigguy810
  • 448 Answers
SOURCE: kohler shower valve trim on temptrol mixing valve
all mixing valves are the same if you have one in you can change the guts or you can install a new one in a different location i have allways installed them at the hot water heater it makes things easy to service or replace
Posted on May 23, 2012
Cold water going through to hot side
Replace pressure balancing spindle part number 500520 from Kohler, if you purchased part Kohler warranty may cover issue, Kohler Customer Service 800-456-4537
Apr 09, 2014 | Kohler K-2971-KS-NA Hiflow Rite-Temp Valve...
Kohler shower valve trim on temptrol mixing valve
May 23, 2012 | Plumbing
Can I solder the threaded copper adapter to the valve housing? I installed a Kohler K304 (Failed to use teflon tape on the hot side copper threaded adapter). It is all installed and has a slight leak at...
I wouldn't risk it in case you ever need to remove it.
I would drain the system down, take it off again and refit with tape or a sealing compound such as Bossfix.
Feb 23, 2011 | Kohler K 304 Rite Temp Pressure Balancing...
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Sep 12, 2010 | Kohler Plumbing
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
No hot water comes out of faucet
clogged mixer valve. disassemble and you may find a small prticle preventing the valve vrom shifting.
Dec 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
665 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
