Question about Garmin GPS
How to transfer garmin nuvi 250 favourites to sd card
Take the CD card out of the Nuvi and mount it onto your PC in a separate drive (via card reader or something similar).
Connect the Nuvi to your PC and copy "/garmin/gpx/current.gpx" from the GPS drive to the drive with your CD card.
Should you ever want to load these onto a new GPS, just add that same file to the corresponding folder on your new Nuvi.
Posted on Feb 27, 2009
I have a garmin nuvi 250 can i use an 8 gb memory card ?
According to Garmin, your Nuvi 250 can use up to 16 GB SD card ->click HERE
Aug 06, 2011 | GPS
Garmin nuvi 250 cannot read gmapsupp.img file on sd card
It must be in Garmin folder i order to read. (e.g. L:\Garmin\gmapsupp.img)
Feb 15, 2011 | Garmin nuvi 250W GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Want to update maps
Yes, you will need to download the webupdater program from Garmin to get new maps for your Nuvi 200. Transfer the files to your SD memory card and then plug that SD card into your Nuvi 200. Click on the link below to get started
http://www8.garmin.com/support/collection.jsp?product=010-00621-10
May 16, 2010 | Garmin nuvi 200W GPS Receiver
How do I transfer routes to my Garmin nuvi 250
The Garmin Nuvi 250 does not support loaded routes. You'll have to load the waypoints, and then just go from one to the next, to the next. You can transfer the waypoints to the GPS unit with a USB cord.
Jan 31, 2010 | Garmin nuvi 250 GPS Receiver
I have a Garmin Nuvi 200 and cannot load 2010 update
Install the SD Card. When you select your maps and transfer them to the device, make sure the Nuvi is plugged into the USB. When you are on the screen to "Find Device", select the dropdown menu and you should see the drive letter referencing your SD card. Select that and you should be all set.
Jul 17, 2009 | Garmin nuvi 205W GPS Receiver
New Sd CArd-8gb. Trouble completing upload maps.
I have uploaded maps to a SD micro card from my Nuvi 250 to my Nuvi 205 but the 205 wont give me the option to select maps from the SD Card.
Can some one please help.
Thanks in advance.
Jul 08, 2009 | Garmin Nuvi 660 GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
2GB High Speed SD Card for Nuvi 255W
Yeah you can use any of the Ultra High speed SD cards usually around $25.00 on-line for a 2gig. High speed has a transfer rate of about 2MG/Sec The Ultra's are around 15MB/sec transfer rate so make sure that you get a high speed one and you'll be fine. The $6.00 ones are not what you need too slow for map displays.
May 10, 2009 | Garmin nuvi 255W GPS Receiver
Garmin novii 250
You can transfer the UK maps to an SD card which you can then insert into the Garmin. This way, you'll have both UK and Australian maps on your GPS. Got to Setup to choose which map you want to view.
Sep 08, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
553 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
