Is the polarity important in wiring a new TV cord
    Master:
  • 518 Answers
Yes. Especially so on a 3 wire cord.
Green to Green
Black to brass colored screw
White to silver colored screw
Geno
Posted on Aug 02, 2008
What kind of electrical cord does hct flat screen tv uses?
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 07, 2014 | Televison & Video
General electric model number 2 9290a
Sep 08, 2014 | Televison & Video
I need replacement power cord
Sep 05, 2014 | Coby LEDTV2326 23 TV
Replace Power Cord - Technics 1200 MK2
It's an ac cord. there is no positive and negative. the solid black side is "hot" and the ribbed or striped side is "neutral".
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Can someone please tell me which side of the power cord has the larger prong of the polarized plug for Kenwood Electronic Heater #EW6708K
Assuming this involves a USA power system, the larger (usually silver) prong is the "neutral" contact. The smaller (sometimes gold) blade is the "hot" contact. If you are using a 3 wire cord cap, the round or U shaped pin is the "ground". Two wire cord caps should only be used if the equipment (heater) is electrically double insulated. The existing cord will determine which cord cap can be used. It is also important to use the correct ampere rated cord cap.
As for your heater cable, the easiest method is to use an ohm meter to identify the wires. Open a plate or panel on the heater near the cord. The "hot" wire will be connected to a fuse or switch on the heater. Ensure the switch is off or the fuse is pulled (to isolate the wire from other components), then use an ohm meter to test from the "hot" terminal to the other end of the wire (continuity check). The display readout should be very near zero (less than 10 ohms). Repeat the process for the other wire.
Oct 23, 2012 | Dryers
Hi, I have lost the ac power cord for my NC-E2 Canon battery charger. Is there a similar cord I can buy from Best Buy or Circuit City that will fit? Thanks in advance. JD
You need a UNIVERSAL POWER CORD, NON-POLARIZED
you can buy at
http://www.allelectronics.com/make-a-store/item/LCAC-400/2-CONDUCTOR-POLARIZED-CHEATER-CORD/1.html
see these cables has round and square ends.(click Zoom and Look the picture)
If the hole in charger have two round corner buy
http://www.allelectronics.com/make-a-store/item/LCAC-390/6-2-COND.-UNIVERSAL-POWER-CORD-NON-POLARIZED/1.html
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Canon NCE2 NIMH Charger Battery Charger
My tv Adapter is not working and i need another one . this what is at back of the ADAPTER AC ADAPTER SN 0530+___O___- MODEL ;AD0603S110/220-12 INPUT:100-240V~1.5A. 50-60HZ .OUTPUT:12VDC= 5A THAT...
The important information is the output voltage (12 volts DC) and current (5 amps). You need an adapter with those ratings and a plug with the proper size and polarity to fit the TV. If necessary, you can salvage the output cord from the bad adapter and splice it onto a replacement if you can't find one with the right plug. You need to be careful to get the polarity right or you can damage the TV. Most sets have the center pin positive, but you want to check to be sure. The set usually is marked with the information, and it may also be on the old adapter.
You may be able to find an exact replacement adapter by searching for your specific TV brand and model number and "replacement power adapter". Many adapters are available through eBay sellers. Otherwise just look for a 12-volt 5-amp adapter and change the output cord as described if necessary.
Good luck and thanks for using Fixya!
May 16, 2011 | Goodmans 289NS 14" TV
No power
There are two problems which are common with the line cord on appliances. Don't overlook these really simple things when troubleshooting your vacuum cleaner - or fancy electronic equipment! If wiggling the cord has an effect, then the following are likely causes:
Repeated flexing results in the internal conductors breaking either at the plug or appliance end. If flexing the cord/squeezing/pulling results in the device going on and off, it is bad. If the problem is at the plug end, cut off the old plug a couple of inches beyond the problem area and replace just he plug. If the problem is at the appliance end, an entire new cordset is best though you can probably cut out the bad section and solder what remains directly to the mainboard.
In either case, observe the polarity of the cord wires - they will be marked in some way with a ridge or stripe. It is important that the new plug be of the same type (polarized usually) and that the cord is wired the same way.
The prongs do not fit snugly into older worn outlets. This can usually be remedied by using a pointed tool like an awl or utility knife to spread apart the pair of leaves often used to form each prong of the plug. If the prongs are made of solid metal, it may be possible to spread them apart - widen the space between them. Alternatively, get a 3 to 2 prong adapter just to use as an intermediate connector. Spread the leaves of its prongs. However, a new outlet is best.
Bad connections on the mainboard. As you flex the cord, it is also stressing the attachment to the mainboard and affecting some marginal solder joints.
It is important to deal with these symptoms as soon as possible as erratic power cycling can lead to much more serious and expensive problems down the road.
Good luck...
Jun 03, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
The cord to the tv is broken
You can find an electrician who can repair this. He will be sure to wire a new cord in, using correct polarity, which is a must.
Jan 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
