Question about Onkyo TX-SR502 Receiver
How do I connect to set top box, The set top box is connected to the TV via HDMI.
  • 417 Answers
Your set top box should have secondary RCA outputs along with the HDMI. run another RCA standard yellow- red- white cable to the Onkyo's video 1 input. Use Monster cables for best performance..
jm
Posted on Mar 20, 2011
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Television say check signal cable . I have a scientific atlanta cable box.What do I do?
How is the TV connected to the cable box (HDMI, component video, etc.)? Make sure that the cables are securely connected and that the TV is on the correct input. Try swapping the current cables for new ones. (The HDMI cable has come loose on my entertainment system at times.) If you route HDMI cables via a sound receiver (cable box -> receiver -> TV), try a direct connection to the TV.
For my TV, I have to turn on one set-top box before I turn on the TV to get the signals to correctly synchronize. (Try turning off everything connected to the TV and then turn on the accessories first. Then turn on the TV.) For another set-top box, it needs to be turned on before the TV. (So try both options.)
Make sure that your set-top box is on and try a different TV or input if possible. If a second TV doesn't work with the box, contact the provider and check for a service outage. (Also try a different set-top box (like a blu-ray player) to check if it is the input on the TV.)
Note: I've had mice or other things damage wiring; this takes out the cable and phone lines. If this is outside damage, your service provider should repair the damage for free.
I hope this helps. Please add a comment with more information about your TV and the connections that you are using for additional support.
Apr 25, 2013 | Televison & Video
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
HD set top box to PC via HDMI
it should be an HDMI Output, you should be able to hook up to a monitor with no problems but directly to a PC, not so much. In what way will you be using this application, that may help
Apr 27, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
LG Plasma 42PC56 optical digital audio out
I can't imagine your setup. Box, tv and pc speakers?
Typical setup would be box, tv and some kind audio system with optical IN. Correct wiring would be connect box to tv via scart and connect optical cable from BOX to audio system. You have to go from box not from TV since scart connection doesn't carry audio signal. To have TV to output optical audio out you would have to connect it to box via hdmi.
Dec 02, 2017 | Televison & Video
How to switch from Computer to TV if the PC is connected via D-sub and Set top box via HDMI port
Most LCD displays have an input select button to choose the TV ot PC display. You just press the button and it cycles thru the options. Normally starting with VGA, then DVI and then the remaining input options.
Jun 19, 2008 | Computers & Internet
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Onkyo TX-SR502 Receiver Logo
145 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
