Question about Toro Lawn Mower With Toro Power Tools
P have a Toro riding mower and found that when I drained the oil it appeared to have gas in it. Last season near the end of the year it would blow a black liquid out the exhaust when it started.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 130 Answers
It seems the carburetor is flooding and overflowing into the crankcase. This is a common problem. Need to determine what type of carb. you have: Walbro or Nikki to suggest a fix. Some simply put an in-line shut off valve between the tank and the carb. and turn the fuel "off" when they are not using the mower. You will need to change the oil and oil filter (if you have one). Hope this helps.
Posted on Mar 20, 2011
Engine smokes on first use this season.oil level is correct.did not smoke when last used previous season.
It probably ok. Smokes because of sitting. If contint bad rings, air filter?
Feb 27, 2016 | Garden
Fuel getting into the Oil (single stage)
Try turning off the fuel valve near the tank when not using
Dec 15, 2013 | Garden
Ariens snowblower won't start
Did you drain the gas from last year? Gas is only good for a few Months. You should always run the machine dry at the end of the season or add Fuel Stabilizer at the end of the season. Id start by getting all the old gas out of the tank and the fuel Bowl on the carburetor. You will also want to check for spark. to make sure there are no electrical issues. Check oil level also. Depending on machine it may not start if oil level is to low alot of machines have a oil pressure switch.
Dec 14, 2013 | Garden
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Mar 19, 2012 | John Deere 22HP Hydrostatic 42" Riding...
I have a 2cyl Mantis that has a problem. The pull cord pulls very hard. When I take out the plug the engine turns over ok. Was ok at the end of the last season, I drained it and put oil in cyllinder. What...
pull it a few times to get the oil out off the cylinder 2cycles dont run on heavy oil well put fresh plug
in with gas and oil and try again you did use oil and gas mix last year right
Jun 12, 2011 | Garden
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
I have a toro lawn mower. For the last 3 seasons the carb get srcewed up. Usually early in the season. The mower just stalls, and then will not stay running. It seems like it just runs out of fuel. What...
If replacing the carb fixes the issue it is likely just dirty or bad fuel in the old one. make it a habit of running your mower out of fuel at the end of the season and ALWAYS use a fuel stabilizer in your outdoor power equipment fuel
May 26, 2010 | Toro Lawn Mower With Toro Power Tools
John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Apr 06, 2010 | Garden
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
267 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
