Question about Whirlpool Washing Machines
A red alert appears which states to clean filter, can you please describe where the filter is?
  • 3 Answers
Usually the filter is accessible from front lower part of the mashine. sometimes you have to remove plastic cover first by unscrewing or pulling it. Filters are usually installed in place with screws or locking mechanism.
Posted on Mar 20, 2011
Keurig reservoir lite still blinking after water added
Make certain the container is flush with the body of the coffee maker. Press it in tight and if that fails, the contacts may be coated or need repair. Clean with vinegar as stated in the manual to clear deposits. Average...replace filter 3 Mo. Clean 6 weeks depending on Hard or Soft water conditions.
Jan 22, 2014 | Keurig Platinum B70 Coffee Maker
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
Have a first alert et220 timer. After setting it and turning back to current time, pm light goes out and clock does not run. Manual switch works fine
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
Sep 09, 2011 | First Alert 24 Hour Timers - 2 For The...
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
The only thing that comes up is a Red Cross Antivirus window, cant seem to remove it. I already have an antivirus downloaded.
Red Cross Antivirus is a rogue anti-virus program that is installed via the Fake Microsoft Security Essentials Alert Trojan. This rogue is installed via a fake Microsoft Security Essentials alert that states you are infected and then prompts you to install 1 of 5 rogues, including Red Cross Antivirus. When the program is installed it will reboot your computer and start before you see the Windows desktop. It will then scan your computer and state that there are numerous infected files found, but will state that it will not be able to clean some of them as it requires the heuristics module in order fix them. In order to activate this heuristic module you will need to first purchase the program. This is a scam, though, as none of the files it states are viruses are actually infected.
Go to TrendMicro.com and run a free online virus scan to eliminate this rogue.
Jim
Sep 26, 2010 | Compaq Computers & Internet
Red alert 3 registration code can u gave me pls so i can play
hey there welcome to fixya
i hope this helps please follow this link
please remember to rate this solution
regards
magical ink
Jun 19, 2010 | EA - Electronic Arts Command and Conquer:...
Clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Washing Machines Logo
24 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
