AuCentrex microwave model CTMW28S cover over vent rigthand side, brittle and bent, held by 2 screws. Can I buy replacement please?
  • mk_bk Mar 20, 2011
    Please read my question. Its a microwave oven NOT A WASHING MACHINE
  • 10,865 Answers
Hello mk.. Contact a local store that carries this brand to see if parts are available. Also, if this microwave is over 3 years old consider replacing it for two reasons. First of all the new ones are much less money and secondly they use much less power. A new one will pay for itself during it's warranty period.
The problem with replacing parts is that the parts are difficult to locate and when you do, they are very pricey. Joe
Thanks for choosing fixya!
Posted on Mar 20, 2011
  • 12,061 Answers
Hi, while these MW's were popular there was never many spare parts and bits for the case were almost non-existent for some models. Other were just impossible to find... :)
So I doubt that anyone would any longer stock these parts. but it may be worth a Google?
One way that you maybe able to obtain some parts would be to ask on Ebay, or as said prior, inquire via the 'net also don't forget chat rooms among like minded people.
Often with careful handling, covers, hatches and grills can often be rehabilitated with a gentle manipulation and a soft faced hammer, then a coat of paint, and often one can barely notice where the damage was, or I have even made "Patches" out of other bits of tin plate, aluminum, even plastic, as long as it fits, and looks good, it works.
I have a GE Microwave Model # JVM133OBW. The interior light went out. How do I replace it?
Typically you remove the vent cover just above the door that goes all the way across the top of the unit. There are 2 or 3 phillips screws in the front of it, or on top. You take out that plastic vent grill and look behind it. There is another screw in the center that holds down the panel the light bulb is held in. So, remove that screw and lift up on the panel holding the bulb. Make sure you unplug the Microwave before you take out the bulb. Sometimes the glass will seperate from the base and the wires inside will twist together and blow up your circuit bosrd. SO UNPLUG FIRST!!! On that top grill some have the screws on the Top of the unit, but you just have to find the screws that hold that top front grill in place. Some of the grills have to slide to the side a bit to come out. I am sorry I do not have exact instructions on YOUR machine. But it really is not that difficult. It could be a screw in type bulb or a small push in Halogen. Good Luck
Oct 16, 2017 | GE Microwave Ovens
Bulb replacement
Is it an over-the-range (OTR) microwave or a countertop microwave? If it's an OTR microwave, are you talking about the light(s) on the bottom of the microwave, or the one that lights up the cavity when you open the door or run the microwave?
If it's an OTR microwave, and the cavity light is burned out, you MAY be able to access it by removing the grill vent by removing the 2 to 4 screws above it. Then, depending on the model, either slide the grill vent to the left and pull it out, or else pull out the top part of it first. Then, if there is one, you may see an access cover behind the grill vent. Unplug the microwave, then remove the 2 screw that holds the access cover in place, and lift up and remove the cover. You should now be able to get to the light bulb.
If it's a counter-top microwave, you will have to remove the complete cover by removing the screws on the back, and possibly a couple of the sides. Note, 2 screws are special security screws to prevent the casual customer from fixing his own microwave oven! UNPLUG THE MICROWAVE FIRST, then remove the cover screws. Slide the cover back about 1/2 inch, and then it should come completely off. You should now be able to see the light bulb to change it. Then reverse the process to put the cover back on. I hope this helps.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 21, 2014 | Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
How do i change the light bulb on a Kenwood Ken GJ/SS25 microwave
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 02, 2011 | Microwave Ovens
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Interior Light
If it's avantium, it's on the web, but it's a real pain and requires small hands.
Pull the power before getting thbulb.
Jan 01, 2008 | GE Advantium 120 Convection/Microwave Oven
Charcoal Filter Replacement
I have the same model. There are 2 sscrews that hold the grill cover on. One problem might be that your cabinet are covering those screws. They are both located about 1" back from the front edge of the door. The left side is about 3.5" from the left edge & the right side is 8.25" from the right side of the unit. My cabinets are 12" deep & I am able to access the grill cover screws with no problems.
Jan 14, 2007 | GE XL1800 1100 Watts Microwave Oven
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
