Question about Watches
I have a vintage papermate ballpoint pen that the mechancial clicker doesn't work correctly. When I press the clicker down, it pushes the fill through the hole but as soon as you release it the fill retracks back in the body. I think, the spring or the plastic piece inside it broken??? How can this be fixed because I don't want to get rid of the pen or who do you know that I can contact to send it too or request parts to fix?
  • 1,830 Answers
    Top Expert:
  • Watches Master
  • 27,169 Answers
Contact Papermate.
http://inkjoy.papermate.com/
Posted on Jul 10, 2017
4 Suggested Answers
SOURCE: Garmin Forerunner 50 Battery Replacement
Thanks MarcS_Ca - I've supplemented what you offer with some photographs at
http://gnjmch.com/public/tips/GarminF50.Battery.html
Posted on Nov 07, 2008
SOURCE: I have a Corum ballpoint
Hi Stuart,
I have the same bp as you. Why donot you ask Corum if it is to be repaired. Maybe they can tell you who the manufacturer of this pen was. I think Delta or Montegrappa was the manufacturer. Mail to cdubois@corum.ch. She was in 2008 working for Corum when I asked Corum more info about this ballpoint.
Regards
Wim Ammerdorffer
Posted on Jul 31, 2011
ansel_albert
  • 248 Answers
SOURCE: The stem pulled completely out of my watch.It
push it inside while you were turning it until you feel something in inside locks, but if not effective, yur watch must be opened to pus the lock inside while you are inserting the stem. if still not effective, your watch module has to be replaced by a new one. i hope this thing will helped you a lot.
Posted on Sep 12, 2011
How to set time and date on a batman kid digital watch
Is it a BAT 4045? It appears this is a watch with poor or no instructions and ineffective time/date settings, which might be your situation. I found this review on Amazon which might help you.
Solid w/ a configuration issue
Byartayd2on 8 July 2013 - Published on Amazon.com
Verified Purchase
I've seen a few reviews indicating that they could not set the clock or the instructions were not included. While I did get correct instructions, they were not written well and seemed to be the end result of someone translating into English.
I had issues setting the time/date w/ the S2 button initially because of the specific location where you are required to press. It is not sufficient to push the S2 button to begin setting the clock, you really need a pen tip to press it squarely or you will continue to press the button and no time setting options will appear. I originally tried to set the clock by pushing the S2 button with a small thin pair of scissors that were handy but it did nothing even though I was clearly pushing the button into the watch face. After changing to a pen tip it worked right away.
With the exception of the initial time setting frustrations the watch works well and the strap feels strong enough for regular use for my three year old son, and it is pretty cheap!
Nov 26, 2017 | Watches
How do I set the time on a 2 button Reebok vintage digital watch? It came with no instructions.
hi.i dont own one nor have i seen one but ive had old watches before. instead of just pressing the buttons try holding them down 1 at a time and hold the button until the digits flash. which ever button makes them flash the other one will change the time. another way is to press the button 2 or 3 times quickly ? and last try would be to look around the side of the watch and you might find a very small indent ( usualy between the buttons ) .. some of them need a pin to push that in to change the time. there the only ways i know,hope this helps
Apr 28, 2015 | Reebok Watches
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
We purchased a Casiotron R-11 watch, model number 54194. After many years the battery has gone flat, we replaced this but are not too sure how to set the time and date etc. Please can you...
Hey there, Setting the Time on the Casio R-11 until the R-15 ist quite simple: insert the Battery, the you should see the seconds counting on the top of display- depending on the model there are bars or squares blinking every 5 seconds and progressing until one minute is done, then it starts again. When all the bars for the seconds are filled, simply press the button located on the left side of the watch. You can press it by using a pen etc. Now the Hours start running, let proceed until the right time is displayed (notice the a.m. or p.pm. bar on the top/right of the display). When you reached for example 10 (for 10:00 in the morning or night), then you push the select button on the right,then same procedure with the minutes. When you finished selecting the hours and minutes press the button on the right again and the watch starts with the time with 0 sec. You cab set the date by pushing the select button on the right and simultaniously pushing the button on the left with a pen.
Hope it works out
May 05, 2011 | Casio Watches
I lost my manual for setting time on a White Deuce Watch. Where can I find instructions
You will need something with a fine point, like a pen. Turn the watch inside out and you will see two small buttons that are used to adjust the time. Place the tip of the pen on the top button and press it 4 times - or until you see the P or A pop up (PM or AM) or time (hour or minute) or date (day or month) flash. Then use the tip of the pen for the bottom button and press it until you get the correct hour of the day. Hit the top button again to get to the minutes. Press the bottom button until you get the correct minute of the day. Press the top button again until you get back to deuce blinking on the watch and you are done.
Dec 24, 2010 | Guess Watches
I have a Corum ballpoint pen retractable, it has flags on the clip, body made of stainless steel, the clip has lost its springyness and is free to open and close without any spring pressure, and also the...
Hi Stuart,
Regards
Wim Ammerdorffer
Oct 14, 2010 | Corum Watches
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Nov 16, 2008 | Tissot T-Touch T33759851
Watches Logo
53 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
