Question about HP w1907 LCD Monitor
Iam using HPw1907 Monitor. THe backlight of the same goes off for every 10 min . What is the solution ?
    Problem Solver:
  • 6 Answers
You can adjust power settings that control monitor. if you using Windows 7 you can modify your display settings in Control Panel / Power Options screen. For additional help you can read this guide.
Posted on Mar 20, 2011
HPW1907 monitor goes to sleep and says no input signal. Why? How do we fix this problem?
Hello.
Your monitor is not getting the input signal from your computer. Check to see if the cable from the monitor to your computer is snug.
Test this monitor on another computer, if possible, to see if your monitor or computer is the problem.
Hope these suggestions help.
Oct 23, 2010 | HP w1907 LCD Monitor
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
Monitor randomly goes to sleep
Sounds like it may be a backlight issue. Try using another monitor if possible and see if the same issue occurs. If it does, then it's the backlight in the monitor. If it's not this, it could be as bibleman01 mentioned a software conflict or an issue with the graphics controller failing.
Dec 15, 2008 | Dell Dimension 4600 PC Desktop
Inverter board for mag innovision monitor
Hi...there,
It's seems you need a new backlight inverter. The one you had have a burnt out capicators. You can either replaced yourself or order a new one. Good lucks!
Sep 18, 2008 | Computers & Internet
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site out...@ www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Sound problem on TV monitor L 2010
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Feb 07, 2018 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Acer AL1916W 19" LCD Monitor Blacking out
This is not a setting or driver issue! The best way to determine this is to connect the monitor up to another device to see if the same thing occurs! If it does then your backlight is in bad shape and it is starting to go bad. It will generate enough power to display some images, but when it continues to be on for a certain peirod of time it goes black. This is common when the backlight is starting to go bad!
Oct 04, 2007 | Acer AL1916W 19" LCD Monitor
HP w1907 LCD Monitor Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
