When I try to run a Diagnostic Test, either manual or auto mode, the door locks and that is it. The indicator is flashing on the rinse/spin cycle and when you try to cancel the test. It flashes at the drain/spin. The door switch has been replace and all connector on the CCU have been check. Switches for the door and its locking mechanism show close at the CCU wire connectors. ERROR codes are F21, which the pump was replaced two weeks ago & F28, which happens when the test was running and I manual unlocked the door. The wash is a Whirlpool WFW8500SR00
5 Suggested Answers
  • 2468 Answers
SOURCE: F28 error plus Diagnostics tests
have you checked the motors 3- phase windings for a short circuits,it sounds as this may be a factor in your problem each lead 1&3/2&3/1&2 should show 6 ohms each when unplugged from the MCU and checked individually,from the burn marks in this area of the MCU I would say the motor winding(s) are shorted,and the rest of the unit is shutting down to protect the new board
Posted on Dec 09, 2010
  • 1654 Answers
First the simple solution.Simply pull out (remove) the detergent tray, reach all the way back with your hand and feel for a lever, pull it forward. Given the nature of the F28 error, which indicated the two boards are no longer talking, look at the connections on both the motor control and main control boards along with the wiring harness between the two. The motor controller may be bad.
Motor control boards are used on front load washers to simply control the motor. Most of these motors are three phase AC or DC motors which means they have three windings instead of just one. By properly applying current to these three windings, the motor controller can spin the motor in both directions and at a large range of speeds. The motor controller can also apply the breaks to the motor to slow it down using nothing but electricity.
F28 is also failure of main board to pressure switch circuit. I would bet you their is trash in that hose and the water pressure won't activate the switch while it fills. Just guessing
One more easy try is Remove the front panel. If the flip-top cover to the right of the drain assembly is popped up, then simply pop it back down. This cover holds the wire connectors into the terminals and often pops back up when the machine agitates
Posted on Dec 12, 2010
  • 1554 Answers
SOURCE: Kenmore HE2 stopped mid-cycle. When
This appears to be a problem with the MCU and not the CCU as what has already been found. First, make sure the serial communication connection between the MCU and the CCU is intact, clean, and snug fit. But it seems that you have done all that. The one and simple way to determine whether it is the MCU or CCU is disconnecting the serial communication connection between the two then starting the machine or running the diagnostic test.
The problem is indeed the MCU if the machine seems to work fine with the MCU disconnected except for motor powered functions or the diagnostic test progresses successfully but eventually flashes F28 code (or any other code pertaining to a motor or MCU problem) after the dispenser motor, dispenser contact, hot water inlet valve, and pressure switch test or when the test enters the MCU and motor tests. Replace the MCU then. The problem is the CCU or both if the machine still behaves the same after the MCU is disconnected. Replace the CCU then the MCU if the machine behaves the same after the CCU is replaced. This troubleshooting technique has worked for me all the times the symptoms are like yours and it turned out to be the MCU.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Aug 13, 2011
  • 2341 Answers
SOURCE: Trying to run diagnostics on
What to check next is if the switches on the lower panel below the one where the door mounts,check that when the panel is off that those switch are closed and have ZERO omhs resistiance and the are open when panel is installed. To do the DISCONNECT POWER TO WASHER, remove that panel and check for continuty with the panel off them,then push the switch in as if the panel was on and see if the switches are open with infinate ohms.
If they check to be good ,since of you have already checked for tight good connections on CCU/MCU the MCU would need to be replaced.
Good luck,
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F-26 flashing
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Fron Load washer. Can not unlock door.
There is a manual way to unlock door. I copyed this from the tech sheet.
Manually Unlocking the
Door Lock System
1. Unplug the power cord from
the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of
the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the
door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about
a ¼” or until a click is heard.
6. The door may be opened.
Also there is a test procedure you can run to check the door lock actuator.
The washer must be empty and
the control must be in the OFF
touchpad sequence to start the
Starting the Test Mode
 Close the door.
 Push CONTROL/ON (if present on
this model).
SPIN SPEED touchpad.
within five seconds. (If
PREWASH OPTION is not present
on this model, press RINSE HOLD
four times within five seconds.)
C:00 will light up on the display.
Hope this helps.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service Mode
System Diagnostics
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
