I have a Sharp DVD player connected to my new Samsung TV model UA32C4000. However DVD's only play as black nd white enen though cable connections appear correct.
  • 24 Answers
Try changing the video setting on your DVD player from NTSC to PAL or vice versa depending on what country you are in.
If you cant find it in the menu / set up, have a look and see if you can change it on the TV.
Posted on Mar 20, 2011
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do I connect a Pioneer S508 amplifier to a Samsung Bluray DVD player?
This is a common problem. Not all models of DVD players have analog audio connections.
The image of the back of the DVD is suppose to be a BD5700?
The connections AUX on the amp and the connections audio out red and white RCA connector are connected with a audio cable.
The images marked with the red are these locations
If your model of DVD player does not have a set of red/white audio connectors you have two other choices.
  1. If TV is connected via HDMI that the audio is included to the TV. The TV will likely have a set of red/white audio "out" RCA connectors that would connect into the Pioneer.
  2. Purchase a specific powered adapter that takes the Optical audio signal and converts to a analog RED/White RCA connector that will connect via audio cables into the AUX of the Pioneer,
Dynex Optical Coaxial Digital Audio to Analog Audio Converter Black
Jan 07, 2016 | Samsung BDD5700 BluRay Player
My samsung dvd player displays only black white.
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur.
Ref: http://downloadcenter.samsung.com/content/UM/201011/20101119135155515/HT-C330-EUR_ENG-1025.pdf
Dec 17, 2012 | Computers & Internet
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
Just connected my 4 yr old Jwin DVD player to a new Samsung HDTV. I am using "red, white yellow" connecting cables for the "audio; video in/out" as my connection. S-Video and Coaxial...
Those RCA jacks you are using might be the problem. Lowest Quality only means your TV is ment to handle 720 to 1080 lines- the RCA cables you are using can only handle up to 500 lines. The likely culprit is the RCA cables are low quality or bent or worn. Get new RCA cables and try again. Just be sure the plugs go all the way into the connectors and the wires are not crushed or chewed on by a pet.
Jun 02, 2017 | Jwin JD-VD147 DVD Player
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
My Sharp DVD player only plays in Black & White. I can't get color even though my TV channels are in colour. Any ideas?
It may be a color system setting your TV or the cables might be connected incorrectly
Aug 08, 2009 | Televison & Video
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
When I connect to my TV it only plays black and white
Try to adjust your PC to NSTC if your TV nstc if your TV is PALCAM try also ajust palcam.
Dec 28, 2007 | Shinco SDP-1720C Portable DVD Player
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
