Question about Dishwashers
I have been given dishwasher by a friend, she was using it in "portable' mode in her laundry - attached it to washing machine water inlet tap. I am planning to do the same, but want to know if it should be attatched to the hot or cold tap? thanks
  • 3,018 Answers
For the portable dishwasher you will want to hook the hose up to the hot tap.
Posted on Mar 20, 2011
My aw-1160s toshiba washing machine.The problem is water very poor in.How to solve that?
There will be a filter on the inlet feed of your water hose either at the point of the Tap or at the washing machine end . Check them and see if it is blocked.
Mar 07, 2018 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
How to fit Inlet hose and Water discharge hoses online manual not clear enough
the hose connections should be 1/2 : NTP thread ( normal 1/2 tap and garden hose fittings ) the inlet hose comes from a pressure source so it will be a screw on fitting at each end
Y fittings are available from a hardware shop if you want to run hot water as well as cold but some machines heat their own water to near boiling for better hygiene and drying of dishes
next the same screw on fitting ( as on a tap)) should fit on the pump outlet
as the pump discharge is low pressure the fitting can have a hose tail ( plain piece with a barb at the end that the hose pushes over)with the hose pushed on and held in place with a hose clamp
the same for the other end but the tail should be part of the sink drain ( all fittings can be from a hardware shop in the garden hose section) S bend so push it on there , again with a hose clamp
check the size as the pump fitting may be 3/4 not 1/2 inch as drain hoses can be larger , but the principle of fitting is the same
Aug 20, 2016 | Beko DE2542FS 45 cm Silver Freestanding...
Why does my washing machine take so long to fill?
Check to see if the screens are clogged on your water inlet valves. Just turn your water off at the Hot and Cold faucets, then remove the water hoses from the back of the wash machine.
The section that the hoses were attached to on the back of the wash machine is the water inlet valve (or valves). Take a flashlight and inspect for blockages on the screens (they're located right in the valve inlets).
If you see grit or calcium build up, you can usually pull the tiny plastic screens out with a pair of pliers and clean them out under running water. Then, put them back in and hook everything back up. Turn on your Hot and Cold faucets and see if your washing machine fills faster.
It should work, but if not, you'll need to replace the water inlet valve (or valves, depending on your model)
Oct 15, 2014 | Frigidaire Washing Machines
Dishwasher will not fill with water
depending on the make and model of dishwasher the solution can vary. A good guess (assuming the inlet hose is connected and tap is turned on), is the water pressure setting may not be matching with your normal mains pressure. Check installation instructions for setting mains water pressure. Also some dishwashers like Bosch have special inlet hoses which detect water leakage and shut of the water inlet valve. Need to check if your dishwasher has got this feature and need to confirm the hose is correctly fitted.
More importantly check when you turn wash cycle on if you hear click of the inlet valve or not.
Dec 29, 2012 | Dishwashers
Our machine works fine, but the water just trckles in when it adds water for the rinse cycles. It can take 20 minutes to fill the tub.
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. Replace the water valve with this part.
Jan 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Lack of water
First close the main water tap. Then the following.
Check the water inlet hose at the washing machine entering point. You can turn the knob and remove the hose. You will find a strainer attached to the inlet pipe. pull it out and clean the strainer. Replace it the same way. Do not miss the rubber parts. Do not forget to open the tap.
Apr 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Subject is Bosch dishwasher SHU6800. There is a soap residue left on dishes. Residue is not visible. Using two glasses taken from a recently completed wash cycle I rinsed one under tap water and then...
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 17, 2008 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
