Question about Dishwashers
Dishwasher only washes with cold water! How do we remedy this? (Stainless Parmco TD6S-F1) We have no manual for it, how could we obtain one please? Thank You.
    Sergeant:
    Champion:
  • 218 Answers
Sounds like the heating element is bad. go to http://manualstock.com/search.php?cmarque=PARMCO&modele=TD6S-F1-44 for the manual.
Posted on Mar 20, 2011
How do i turn on and operate a pharmco TD6S-F1 dishwasher
See if you can find the manual on the internet by typing in the Mfg. and Model #.
Oct 14, 2014 | Dishwashers
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Dishwasher error f1
The manual states that fault code F1 means that the flood switch has been activated. They recommend turning off the water and power to the unit and calling them. Their phone number is: 1.888.936.787
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/529543CDD605userguideUSCAw.pdf
Nov 26, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Le error when water gets near the top of the fill area verified water hose ok and changed inlet solenoid valve
hope this helps
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Jun 27, 2010 | LG LDF6810ST Stainless Steel Built-in...
About GE Dishwasher
well all I can say is, I have ONLY cold water connected to mine, A Parmco, & it works fine? I have many friends, using the same method. It will however take longer to wash, and as you say must heat the water up. But so what? I wonder if you aren't being told "Porkies"? Also "Connected" and "Being used" are two different things, right?
Feb 24, 2010 | Dishwashers
I stupidly put washing up liquid in my very old Bosch SPS 21/24 as i had run out of dishwasher tablets - a few bubbles leaked out but all seemd fine and now it makes all the right noises but nothing...
Take a shop vac and remove all the water and suds.
No shop vac...use a towel or sponge.
Then use a pot to manually fill the dishwasher with cold water. Set it to wash a few seconds then go to pump out setting.
Re-fill with cold water and repeat this process until the normal sounds return and the washer is clear of suds.
HOT water will not work. It only makes the suds worse.
COLD water only.
Repeat repeat repeat ubtil clear.
May 14, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
Our dishwasher goes straight from rinse to the endwithout going through the washing cycle. How do I change the cycle? Have tried holding the button to change the cycle, but doesn't change. The dishwasher...
It turned out that the pipe bringing the water into the machine had a kink in it. We pulled the machine out and straightened it. A dishwasher technician suggested we look to see if the pipe taking water away from the machine might be the problem, but it was the incoming water pipe.
Jul 24, 2008 | Dishwashers
Dishwashers Logo
350 people viewed this question
Top Dishwashers Experts
