Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet I need to change the gray front boot on my Duet washer, can you help with this - Thanks
  • nicholsm4 Aug 04, 2008
    That did the trick - thanks for the help!
  • Anonymous Aug 18, 2008
    Door leaks and clothes are always getting stuck and being ruined. Unit is two years old and I am thinking of junking it.
    Your thoughts.
  • 246 Answers
Since this is already marked solved, I am just noting it to get it off mylist.
Posted on Aug 18, 2008
    Scholar:
  • 97 Answers
Hiya
firstly you will need to unplug the machine, then remove the lid, open the door and remove the metal retaining band from around the lip of the door seal (may need a small flat screwdriver to lift it up).
once the retainer is off the door seal should pull away from the front lip, this can then be folded inside the machine and out of the way for the next bit.
next you will need to locate the doorseal retainer on the inside of the machine may need a 7mm socket and small ratchet or a small philips screwdriver for this one, this one only needs to be loosened enough so that the doorseal will pull away from the drum.
refitting is pretty much the reverse of removal.
you MUST make sure the seal is on the drum lip corrrectly before refitting the retaining band or it will leak.
you MUST also make sure the drain holes are lined up with the ones on the drum.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 04, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front loading duet whirlpool washer (1.5 yes old) front seal is torn. Can you please send me instructions to replace it myself? Thanks.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
above is a link to a service manual that will help guide you thru this repair.This is a tedious repair that can be tough for the homeowner ,there is a lot of disassembley needed to get to where you can reinstall the new door boot correctly. removing the old part is easy but to install the new one will take patience dont try to cut corners or you will be doing it over again Hope this Helps Good Luck
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to change Whirlpool Duet front-load washer (model: GHW9100LW1) rubber seal (the bit gray rubber ring that's between the front door and the drum)?
If you are referring to the door bellow, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The plastic boot has a rip in it. How difficult is
If you are referring to the door bellow (gray rubber seal), the following link explains how to access and replace one:
Replacement parts can be found at any of the following websites:
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites also have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
Read through the link provided and if you have questions, please post back and let me know. I hope this helps you.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code F 01 come up on my Whirlpool front load washer and won't do any thing?????
must be a duet sport ..change control module ..remove screws along rear of top panel remove panel by sliding back .control is white or gray box on right near front
Aug 28, 2008 | Whirlpool Washing Machines
Duet washer leaks during use; rinse cycle?
could have a bad boot seal please post your email here and i will send you the service manual on how to change it
Jan 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
