Hi, I have a Samsung washing machine, model SW50USP, which has an error message "5E" appearing on the display. I have done some research on the net and from that have cleaned the internal filter and the external filter plug. The machine still isn't aggitating during the wash cycle and the water isn't draining. I have checked to see if anything is preventing the motor from extracting the water down the waste pipe put nothing seems to be clogging. I do not that the fan is not turning during the spin cycle as it should however. Anyway any ideas on repairing this would be appreciated. Thanks
  • 1894 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
then its stuck drain sir
Posted on Jun 09, 2008
  • 1894 Answers
SOURCE: Speed Queen SC18 Washer-Extractor, (clothes
have you check the drain hose for any leaks?
this can happen due to some damage in drain hose
Posted on Aug 04, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool washing machine not draining.
Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
Posted on Oct 07, 2008
futureloginn
  • 734 Answers
SOURCE: I have an Indesit washing
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Posted on Dec 12, 2008
SOURCE: err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
Posted on Apr 10, 2009
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Error code se on samsung front loader 7kg
could the code be 5e if it is a 5e then the problem would be
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Another tech has also done a previous post to this subject so click here to see her repair as well http://www.fixya.com/support/t5093804-se_mean note that if this repair does not work please message me back and there will be other tests for you if this repair she lists does not work if you have any further questions also message me back with them and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 16, 2011 | Samsung WF337AA Front Load Washer
Samsung washing machine SW50USP. Machine powers up, all buttons and settings work but when press start button the cold light and wash light start flashing but doesnt start to wash. After 2 minutes 4E shows...
I've just had the same problem with my Samsung SW50USP and had a technician out to have a look at it. Apparently the electronics are fried and it would cost much more than it's worth to fix. Time for a new machine unfortunately.
Dec 26, 2010 | Washing Machines
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
Dec 11, 2010 | Samsung Washing Machines
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
