My front seal is busted in my transmission it is 2000 dodge grand caravan i need help finding out how to take my transmission
    Master:
  • 403 Answers
To much to explain online, get yourself either a Haynes, or a Chiltons repair manual. They are very good at explaining, its the auto repair bible as far as Im concerned.
Posted on Mar 20, 2011
Transmission leak.
Hi Al, Im AL the owner of Big As Auto Repair
Transmission leaks on a Dodge Caravan can come from many places. Front pump seal, solenoid pack, axle shaft seals, pan sealer defective, hoses, trans cooler. Look around all these places to see where your leak is then write back so I can help you further. Hope this helps and please send people to my auto-repair-website at: http://www.bigasautorepair.com/
Sep 18, 2015 | 1996 Dodge Grand Caravan
What transmission is in 1995 1995 Dodge Grand Caravan
There are three possible: CARAVAN/GRAND CARAVAN 1995-2000 3 SP FWD V6 30L 31TH A670 CARAVAN/GRAND CARAVAN 1995-2002 3 SP FWD L4 24L 31TH A413 CARAVAN/GRAND CARAVAN 1993-2003 4 SP FWD L4 24L V6 30L/33L/38L 41TE A604
May 08, 2015 | 1995 Dodge Grand Caravan
What happens to your car 2001 dodge grand caravan transmission fluid is over filled
how much overfilled, if it's just a little, it'll generally foam, and could cause the front or rear seal to blow out if more than just a little
Aug 26, 2012 | 2001 Dodge Grand Caravan
The Dodge Dealer is saying the crank seal and cam seal are leaking when they went to change the oil, are these transmission seals or engine seals? do I need to place them or is there a product that will...
Crank seal could either be at the front or rear of the engine (there are two) Cam seal is at the front of the cylinder head. If the leaks are minor, a good product that may help is lucas conditioner and sealer. Larger leaks require an actual seal replacement. No sealer will work immediately. The reason most leak is because over time the seal hardens from heat. It takes a while to soften it up again.
If the leak is from the rear main seal, the transmission needs to be removed to get to it but neither seal is part of the transmission.
May 21, 2011 | 2000 Dodge Caravan
Where do I put the transmission fluid in a 2000 dodge grand caravan with a 3.3 liter engine??
You add the fluid in the same place where you check the fluid for the transmission. normally a yellow stick labeled transmission and its under the hood on the driver side of course. 4 thumbs up is appreciated if this helps.
Dec 29, 2010 | 2000 Dodge Grand Caravan
1996 grand caravan leaking transmission fluid. Used lucas stop leak, still leak use 1 liter per 1000 Km otherwise works fine
so i just changed the seal at the front pump and torque converter because trans fluid was leaking from the bell housing took her for a test drive and still leaking help anyoine it is a 1996 grand caravan 3.8
Oct 17, 2010 | 1996 Dodge Caravan
Our 2001 Dodge Caravan seems to be leaking oil around drive shaft
Yes it's a bad seal and most likely the side bearing to the trans axle is bad too. Once the bearing has play, it vibrates and causes the oil to leak though the seal. Note: if one side went bad the other side is soon to follow since they have the same amount of miles on them. Might as well change both side. Good luck and hope this helps. Keep an eye on the transmission fluid level, don't want to burn out the transmission.
Jun 04, 2009 | 2001 Dodge Grand Caravan
Replace the front wiper motor 2000 Grand Caravan Dodge
It is on the firewall under the hood. It has 3 to 4 bolts holding on. Be careful when taking it out to see how the new one lines back up. Hope it helps.
Mar 30, 2009 | 2000 Dodge Grand Caravan
 Grubhead
Grubhead
