Question about GE Built-In Dishwashera Oven
Dishwasher won't empty water after wash finished
    Sergeant:
    Champion:
  • 218 Answers
Most likely the pump that pumps out the water is bad. You may also check that the drain hose is not plugged between the dishwasher and the garbage disposal.
Posted on Mar 20, 2011
How to clean oven racks
If you mean the straight-in-a-line-parallel-stainless-steel-wire-rod type, we use these methods at home:
General all-round cleaning:
Oven-cleaner spray foam, left to soak to lift grease, then good sponge-down with water-damped cloth / sponge.
Stubborn gunk on racks:
Place racks in empty bath, spray/soak in oven cleaner, or..
pour or squirt engine cleaner / degreaser over entire rack surface, allow to work grease loose, then pour boiling hot water to rinse and dislodge fattiness and carbon.
Ordinary dry washing powder is high in caustic, so also works well.
'Handy-Andy' cream is quite high in ammonia among other unpronounceable chemicals for lifting stuck grease and oils.
Make a stiff, sticky paste of clothes-washing powder and water, then apply to a kitchen 'Zim', ie green scouring pad and mixed with lots of elbow-grease, can restore the racks to former glory.
Rinse well under running water to remove soap.
Otherwise 'bath' the racks in hottest geyser water with washing powder sprinkled on top to soak.
A stiff nylon brush helps to scrub the burnt bits away.
Dec 20, 2017 | Ovens
Hi, I have a Gaggenau DF261160/11 dishwasher, which seems to not heat the water when washing. Does anyone have a service manual for this product?
Does it hot dry the dishes, this would indicate the heating element is ok and the cause is the control board.
Oct 04, 2016 | Gaggenau Ovens
I have a May Tag dishwasher and I am very unhappy. I use Jet Dry and a small amount of Cascade and my glasses get a white film on them. They look terrible. What can I do? Susan Ferrin
Perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 13, 2011 | GE Built-In Dishwashera Oven
Can u put your oven doors in the dishwasher
I have never heard of anyone trying to wash oven doors in dishwasher, personally speaking, I would not recommmend it, as you are not goiung to get even water distribution, and the baked on fat and grease will probably not be removed.
Dec 28, 2010 | Neff Ovens
How to clean inside top of oven above heating element
FIRST TURN OFF POWER THEN SPRAY TOP WITH OVEN CLEANER AND LEAVE OVERNIGHT THEN CLEAN WITH STRONG PLASTIC BRUSH NOT A WIRE BRUSH AS THIS WOULD CAUSE DAMAGE , WHEN FINISHED CLEANING WASH WITH WARM WATER ,
Nov 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE WPSR3120WOWW FIRST WASH WORKED AND DID'T FILL BACK UP WITH WATER FOR THE SECOND WASH AND THE SPIN CYCLE WON'T WORK.
Pop the front cover off by using a putty knife to push the clips in (2) at the seam where it meets the washer's top. Pull the thin hose off the left side of the tub and clean it out. (do this with the tub empty) replace tube and front panel and you are good to go.
Explaination: The goop in the tube prevents air from escaping as the water level droped, thus the washer thinks it is still full of water. If it thinks it is full of water, it will not fill any more, nor will it spin.
To prevent this from re-occouring, I'd suggest filling the machine to the lowest level with hot water and adding several cups of bleach. Run the cycle (with no clothes) to help clear out the goop. Use an extra large rinse to make sure there is no bleach residue before doing a load of clothing again. Do this about once every 3 months, and I don't think you'll see the problem again.
Nov 15, 2009 | Ovens
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dishwasher wont drain water
hello there,
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
do not forget to rate the solution,
thanks for using FixYa
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE Built-In Dishwashera Oven Logo
56 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
