Question about Car Audio & Video
When power key is press on, no power comes on. any help is appreciated.
    Sergeant:
    Champion:
  • 218 Answers
Either the fuse for the radio is bad, or the power wire or the ground is not making good contact. Most often a bad ground is the problem make sure that the ground wire is tightly secured to bare metal and not sandwiched between painted parts.
Posted on Mar 20, 2011
Testimonial: "Thanks, will try your suggestion and come back to you if it works. cheers "
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
My key board used to light up and stay lit now it just comes on when i turn it on than go's out asus k501
It appears that pressing Fn (function key) and Spacebar toggles various power schemes. My best guess at this point is that you accidently did this and one of the power schemes also turns off the backlight on the keyboard to save power. Try this and see if it helps.
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Computers & Internet
How to enter in the bios
Press F10 just after powering the PC, to access BIOS of your Compaq Armada E500 Notebook.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | Compaq Armada E500 Notebook
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
Canon multipass f80 error waste ink near full
ok
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 20, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon MP390 - "Data Error Press Set Key" Message
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Feb 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
Toshiba Satellite A105-s2716 power-up password
Hi, usually to get into bios on a toshiba laptop you press and hold the Esc key or the F1 key. try both of these, if they dont work, try this: 1. Turn on computer by Holding down power button while pressing the ESC key. The machine will beep, then display: Check System, then press [F1] key. 2. Release ESC key 3. Press F1 key If none of these work, we may have a different problem all together, get back to me if so, and i will see if we can find a solution. Hope this helps! Si :)
Sep 26, 2007 | ASI CL51-15 Notebook
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
