Question about WebVoice EvaPhone
After i type in the number and see the add it just takes me back to the number pad and stops ringng
  • 3 Answers
Hello, You can ask support team http://www.evaphone.ru/locale/en#help. I think it's the best and free way for resolution problems. They've write:
How to contact support?In case you have any questions concerning Evaphone services, you can contact our technical support by e-mail: contact technical support
Posted on Mar 30, 2011
Squeak front wheel
depends on what type of pads are in if they are a hard pad they will squeak some times it depends on the weather if its damp a softer set of pads will stop from squeaking you could also try cleaning the rust away from the outer edge take wheel off then by hand turn disk use a spoon or a blunt pice of metal to scrape off the rust normally solves the problem also can try putting copper grease on the back of the pad so when you take your foot of the break pedal the grease sort of sucks the pad off the disk hope this makes sence chears ivan
Dec 18, 2013 | Mercedes-Benz Cars & Trucks
When you get a text messages how do you stop it from ringng out loud
turn the volume down and in settings some times there will be a do not disturb mode
Aug 24, 2013 | Cell Phones
Cant type name into phonebook,it will only type numbers
No you can't lose all that you have in memory, but that is not the solution to your problem.try to dail the number you want to store or save on your phone then stop the dailing the number click on the number you dail again and go to option when you click on option it will bring some list for you click on save then type the name and save the number is there already.
Dec 20, 2011 | Panasonic KXTG7230EM Phone
Hi, I bought an i pad and it before I can get
You can find all these information on your computer. Press Windows key + r (Win+r) you will get the run bar. Now type "cmd" and hit enter. You will get a black screen. In the black screen type "ipconfig /all" and hit enter. You will get all the details. Now while entering in your I pad you have to change only the IP add. For example..on your computer you have..
IP add: 192.168.2.4 Sub Net: 255.255.255.0 Default Gateway: 192.168.2.1 DNS. 4.2.2.2 4.2.2.3
In your I pad you will have to enter like this.. IP add: 192.168.2.15 Sub Net: 255.255.255.0 Default Gateway: 192.168.2.1 DNS. 4.2.2.2 4.2.2.3
So change the last number of IP address. Let it be anything above 15 and below 254.
Hope this helped.!
Feb 27, 2011 | Linksys Wireless-G WRT54GS Router...
Casio TE-2400 Cash Register- Keyboard Orientation
Hi. The previous owner just had PLUs linked to the depts that suited them. to link PLUs to depts,
Turn key to Program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number you want to link. E.g if you want to link PLU 6, then press 6 on the number pad (don't press the actual PLU, just type its number on the number pad)
Now press the button marked PLU. It should be near the other function buttons.
Now type the department number to link to. Use two digits. E.g to link to dept 5, type 05 on the number pad.
Press CASH
Press SUBTOTAL
As for NO SALE button, does it actually show the command NO SALE, or NS on the display when you press it? It may have been removed from the keyboard. Does the drawer open when you finish a sale normally?
There is normally a setting in key features for VAT breakdown on the CASH button. Make sure this is set so that it prints the breakdown. Add on means you sell at a tax exclusive price and the tax is added on to that by the register. Add in means you sell at a tax inclusive price and want the register to show how much of it was tax.
Hope this helps. See how you get on.
If anyone needs a Casio TE2200 or TE-2400 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 11, 2010 | Casio Parts Cash Register PC Desktop
When I am typing the cursor or jumps to another line that I've already typed then I have to stop and go back to where I was typing I can't adjust the touch pad because there isn't an adjustment under the...
Try taking a dryer sheet (like Bounce) and wiping the touch pad with it.
Typically, when the cursor jumps like that, the cause is static electricity. It may be coming from your clothing, your desk or your floor. The dryer sheet eliminates static electricity.
Some techs wear anti-static wrist bands to avoid a problem like yours.
Oct 08, 2009 | Dell F3534 Touchpad
Change Brake Pads on 1993 MR2
take the wheel off (of course) and there are 2 bolts, one top and one bottom on the back of the calipers. remove these 2 bolts and you should be able to take houseing off for easy removly of pads. you will need to compress the pistons (might be screw in type that requires a special tool). once you have pistons back in just add brake pads and put back together in reverse order. MAKE SURE TO ADD THE ANTI SQUEL STUFF UNLESS YOU WANT TO LISTEN TO THE BRAKES MAKE NOISE FOR A TIME.
Mar 29, 2009 | 1993 Toyota MR2
I need to store a lot of fax numbers and every monday send out a mass fax to all of these numbers. How do I do this?
Press Function 72
Choose ONE TOUCH
Put the numbers in one touch positions 01...02...03...etc.
Press Function 73
SET
Choose GROUP
Press PROGRAM 1 on soft pad and name it. Press SET
Add the one touch numbers into PROGRAM 1 by pressing their numbers on the soft touch pad.
01...02...03...etc. SET....STOP
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
KEYPAD
their is nothing you can do unless you have the correct tools to take your phone appart i used to work for a phone repair company and usuall it is just the case of cleaning the pads behind the buttons they either get greasy or if you have used the phone in the rain it only takes one of the pads to get wet or greasy and none of the buttons will work but iff you do take the phone apart remember their is an order to undo the screws and an order to tighten them and they need to be torqed to the right pressure to stop the board from warping hope this helps but i sugest you take it in to be done as you could totally destroy the phone putting it back together after
Oct 29, 2007 | Motorola Mobility RAZR V3
Facebook Apps Logo
65 people viewed this question
Top WebVoice Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a WebVoice Facebook App Expert? Answer questions, earn points and help others
