Question about Gateway 507GR PC Desktop
I have a gateway 507GR, when I boot up I get a "system32\DRIVERS\isapnp.system" error. It freezes after I elect "R" in the repair menu...
    Master:
  • 525 Answers
Try taking out the ram sticks and putting them back in. Then run the repair again.
Posted on Mar 20, 2011
HP Color Laserjet 5550dn printer connected in network configured through server, showing error 0xc0000005 while clicking on printer properties in any client system?
You have hacked or infected files on your computer.
Check your BCD and do the below fix if necessary (at your own risk)
In Windows open CMD as Administrator and type BCDEdit and enter, if your Windows Boot Loader Path is xOsload.exe then you need to remove some files and repair your BCD.
NOTE: you will need to re-activate Windows afterwards, so make sure you have your Windows 7 key handy.
Boot to Windows Repair - Command
Del D:\Windows\System32\xOsload.exe
Del D:\Windows\System32\xNtKrnl.exe
Del D:\Windows\System32\Drivers\oem-drv64.sys
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
Oct 14, 2016 | HP Office Equipment & Supplies
Tip
System Restore Via Recovery Console
<br /> Ever encountered a problem with your computer wherein it gives you an error page saying that a certain file in the registry is missing or corrupt? Unfortunately, with this kind of error, there are times that you are not able to boot into the OS, and therefor you are not able to do a system restore. <br /> If you are using Windows 7 or Vista, you may initiate System Restore via booting into "Repair My Computer" which you can choose via the Advanced Boot Options of Windows. However, what do you do if this does not work, or you are using Windows XP. <br /> Fortunately, there is still a way to be able to restore your system. This involves manually doing the system restore via the recovery console (for XP), and recovery environment (Vista and 7). The only thing that you will need is the OS CD. <br /> Once you have successfully booted into the Recovery Console, type in the commands below and make sure that you press "ENTER" after each line. <br /> <br /> C:\WINDOWS] cd \ C:\] attrib -h-s "system volume information" C:\] Cd "system volume information" C:\system volume information] cd _resto~1 ..._resto~1] dir --- this should list several rp folders [short for restore points] just select second to the last or any of your choice other the the last rp folder ..._resto~1] cd rp# ...rp#] cd snapshot ...snapshot] dir --- the 5 hive files are shown in this format: _registry_machine_software _registry_machine_security _registry_machine_system _registry_machine_sam _registry_user_.default Syntax [Command filename location] ...snapshot] copy _registry_machine_software c:\windows\system32\config\software ...snapshot] copy _registry_machine_system c:\windows\system32\config\system ...snapshot] copy _registry_machine_security c:\windows\system32\config\security ...snapshot] copy _registry_machine_sam c:\windows\system32\config\sam ...snapshot] copy _registry_user_.default c:\windows\system32\config\default ...snapshot] exit <br /> After this, you just need to restart your computer and it should be working fine.
on Jul 25, 2011 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Windows could not start because the following file is missing or corrupt: System32\DRIVERS\isapnp.sys
This usually occur when unexpectedly deleted or corrupted the files cause by a virus or a third party software. All you have to do is repair your OS using your installation CD(XP) and do not reformat your HDD. Reboot your PC using your XP follow the instruction needed then when it come to the Repair, Do Not Repair, or Don't do anything choose Repair and follow again the instruction.
Apr 24, 2011 | Computers & Internet
WHEN TURNED ON IT SAYS "WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: SYSTEM32\DRIVERS\ISAPNP.SYS
Hi in this case you need run your windows cd and choose option for install then it gonna detect that you've got windows instaled already and give option to repair it if you need more help let me know
Aug 26, 2010 | Dell Inspiron 1501 Notebook
I have a Gateway 507 GR Windows XP Home Edition. Windows does not load/Boot, Error message "Not found or corupt. I can hit I think it is F-2 or F-12 (I forget) and go to the BIOS settings, and try and...
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device.
after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Mar 01, 2010 | Gateway 507GR PC Desktop
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
Feb 06, 2010 | Acer Aspire 5315 Notebook
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Gateway 507GR PC Desktop Logo
67 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
