Question about Vacuums
I have a Ferguson step down transformer that takes input as 240V and outputs 115v The model is : TS 115/2000EC I need the wiring diagram for the output side
  • 927 Answers
If it is 240 to 120/115, there should be two high side wires and two low side wires and ground wires, isn't that true?
Please post back, thanks.
Gary
Posted on Mar 20, 2011
How do I convert a kirby ultimate G from 110V to 220V
You can't. The Kirby draws too many amps for a step down transformer.
Ask Kirby direct if they can convert your head to 220V. click Support - Contact
Kirby Ultimate Vacuum Kirby Models
Nov 10, 2016 | Kirby Vacuums
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
From 220V to 110V controller ASM modification, is it possible?
some models and switch behind for convert in that way the transformer had been designed for to do it.
Other models coming according to the country example USA, most of them use 110VAC, other 220VACsuch Europe
However you can ask to the factory by asking if they have a kit for converter to 220vac to 110vac
God bless you
Jul 31, 2012 | Vacuums
I need to find a converter that coverts 220V to 110V to use a blender from south africa
Hi all you need to get is a step down transformer, you need to obtain a 220v to 110 v step down transformer have a look at the below link to get the idea. You will need one that has a wattage of approx 500 watts to be safe. Anyone is as good as another really.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=220+to+110+v+transformer&_sacat=See-All-Categories
Aug 09, 2011 | Vacuums
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Our SteamVac will not release cleaner and water. Everything else appears to be okay. After last use it was rinsed out and left for two weeks at which time it would not work. I would like to obtain a...
click this link directly
http://www.sacreativeservices.com/forum_stuff/steam_vac/
4931375.jpg af5d9a3.jpg The disassembly procedure with photos for this portion of the steam vac is shown in the first image below. This should help you tear down the unit to a point where you can determine the cause of your problem. The wiring diagram is provided in the second image. You may need this diagram to check the wiring if the motor for the brushes is not running. You can view a parts diagram and order parts for the steam vac on the Sears PartsDirect website.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Vacuums
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
110 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
