Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
I plugged my usb in this morning and it isn't working. I checked all my usb ports they all work fine. windows can not connect my usb and it has malfunctioned. I need this to work I have my final project for my online class on here and my final speech for my night class please help me.
  • SanDisk Master
  • 32,281 Answers
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com Flash drives can become faulty if they are not removed fromthe USB port correctly. Please click on this link and follow my instruction torestore your flash drive :- http://www.fixya.com/support/r3598107-faulty_usb_flash_drives
Posted on Mar 20, 2011
  • 4,281 Answers
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
My usb port on monitor isn't working. how can i fix this?
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
Dell inspriation N5010 laptop this laptop all usb port is not working . laptop purchising in 3month and windows 2007 operating system instaled what is problem please sole the problem
If USB devices such as jump drives, digital cameras, or printers are no longer functioning properly when connected to your laptop, the USB ports may have malfunctioned. There are plenty of troubleshooting steps you can complete on your own to get the port up and running properly again.
1.Connect the USB device into a different USB port on the laptop or another computer to make sure the problem isn't with the device instead of the port. Check to see if the device has a "Write-Only" tab. Push that tab into the unlocked position if it still isn't working in a different port.
2.Click "Start" and then "My Computer" if the device works in another computer but not on your laptop. Plug a device into the port and wait to see if the USB port shows up in the list of drives. Click on "Map Network Drive" if the drive does not appear. Choose a drive letter from the drop down menu and then double click the location of the USB device. Click "OK" and try to use the port again.
3.Navigate back to the Start menu and then click "Control Panel." Double click on "Device Manager." Scroll down the list of options and click the "+" located to the left of the entry labeled "Universal Serial Bus Controllers." Double click the name of the USB port that appears in the new menu. Click the "Drivers" tab and then click "Update Drivers." Wait for the driver to finish downloading and attempt to use the port again.
4.Close the drivers tab and right click the name of the USB port. Click on "Properties." Click the "Power Management" tab and then un-check the check box labeled as "Allow the computer to turn off this device to save power." Choose the "Communications Port" tab and then scroll down to the box labeled "Resources." Click the "Enable Device" button and then click "OK." Attempt to use the USB port again.
5.Close the Properties tab and right click the name of the USB port. Click on "Uninstall." Restart the laptop and then plug a device into the USB port. Wait for a new window to pop up and follow the on-screen instructions to re-install the USB port software.
6.Restart the computer and press the "F1" button on the laptop's keyboard once the manufacturer's name appears on the screen. Scroll down through the list of options that appear and highlight the option labeled as "Advanced." Press "Enter" and then scroll down and press "Enter" on the "USB Support" option. Press "F10" to save the settings and finish loading the operating system.
7.Open your web browser if your laptop is running the Windows XP operating system. Navigate to the Microsoft website and download the Windows XP USB 2.0 driver (see link in Resources). Restart the computer and try to use the USB port again.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Computers & Internet
Front usb ports are no longer working after I plugged in an external 2.5" SATA drive. The computer automatically powered off and I had to reboot. Now when I plug in even a flash drive nothing happens....
Hello
The connector of front panel may gone disconnected, you need to check the connector inside the compute and re-connect it properly.
Hope it helps, do rate the solution if so
Dec 26, 2010 | MSI 7529-050R Motherboard
Undetect kingstone flashdisk in windows
Initially check whether any other usb devices are working fine in the windows machine if so check your USB hard drive in other windows PC.If it works fine then check for drivers in your windows and also plug the USB device to the port which was attached to the mother board rather than USB port which was extended by cable.if the usb device not working in any machines there will be a chance for problem in the device.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
IS IT USB?
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Solution
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
Canon powershot A720is continually powers my computer on and off
Don't thru the camera out the window as it is working on the other system.
I assume you are connecting the camera to the computer USB port; if yes, please check the USB drivers of the operating system on the computer. there might be a physical USB port issue, or USB driver issue or USB port over current issue.
Check all this things before connecting ur camera or check with any other USB device.
Regards,
k.vel
Mar 30, 2009 | Canon PowerShot A720 IS Digital Camera
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
118 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
