Question about Mtd Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the transmission and its not worth fixing? The tiller runs great but can't till if the tines do not move. Is there a oil hole to fill transmission? When I turn off the motor I can move the tines to get into gear but am afraid that if I do this it may make matters worse.
  • 3 Answers
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Posted on May 08, 2011
  • mcclr1 Aug 14, 2011
    I too had one that would pop out of gear while tilling. You could hold the lever in but that would eventually bend the shifting fork in the transmission and it would then jump out of the groove in the shifting sleeve. I put new pins on the shifting fork and reinforced it so that it would not bend so easily. It worked fine for a few minutes and then jumped out of gear again. A friend led me to the real solution. The shifting fork is not supposed to hold the shifting sleeve in gear. It is only supposed to slide the shifting mechanism and the detent spring and ball are supposed to do the holding work. I once again repaired the shifting fork but this time ordered a new detent spring part number 932-0863 and a new detent ball part number 741-0862. They cost $4.40 and that was the solution to the problem. I would also order a new shifting fork if yours has been bent. The new ones are a different design that has more reinforcement. It is a lot of work to tear into these so buy the new parts the first time. I was getting adept at the process after doing it three times.
  • David Reaves
    David Reaves Aug 23, 2012
    Any estimates on what it would cost to have a service shop replace the shifting fork and the dentent spring and ball? I am not physically able to disassemle the entire tiller. I need to get an idea about whether I need to replace or repair. Thanks.
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Apr 20, 2010 | Mtd Products Yard Machines 158CC Tiller
Have a rototiller it moves OK but the tines do not turn It is a mtd yard machine rear tine
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Apr 18, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Mar 21, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD yard machine model#216-410-000
either your tine shaft is seized to bushings which requires total dissassembly of unit or you have a failure of drive chain or gear i'm currently repairing one with the seized bushings if you are not a technician i would recomend replaceing unit very costly to repair in any case.
Apr 05, 2009 | Mtd Products Yard Machines 158CC Tiller
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
1,736 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
