I cannot find the system password to port foward please help me
  • Matthew Smith
    Matthew Smith Mar 20, 2011
    the router is a 2wire i38hg from at
    Problem Solver:
  • 14 Answers
No all you have to do is go to 192.168.1.1 or 192.169.2.1    type that in our browsers address bar and it will ask for ADMIN AND PASSWORD and the username and password will be at your router, there you can make a new password or know your system password
Posted on Mar 20, 2011
    Master:
  • 451 Answers
If you don't remember the password for your router.
you can reset your router to factory settings.
the default password could be password or admin depending on the make/model of your router.
once you do a factory reset you will need to reconfigure your router settings.
Port forwarding not working on router cisco 861w. ROUTER nat DHCP IS WORKING. I have used this command to add portforwarding: ip nat inside source static tcp 192.168.0.222 80 interface FastEthernet4...
make sure you enable both tcp and udp port fowarding . worst case comes to worse reset it back to factory settings. or upgrade the firmware (i couldnt port foward until i upgraded my firmware on my wrt model)
Mar 17, 2011 | Cisco 861 Router
I want to change nat type from strict to open when I play Black Ops. My router is a Thomson TG585 v8. How can I do that? Thank You in advance
Step 1: Get your Xbox 360's IP address from the system blade and choose network settings. Then edit settings should show your Xbox's IP.
Step 2: Go into your routers configuration window thru Internet Explorer. In the address bar type in your routers IP address. It should be default at 192.168.1.1 or 192.168.2.1. When you're prompted for a password you have found it =P. If you haven't changed it the username and password should both be admin, and admin.
Step 3: USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
Step 4:Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
Step 5:Using UPnP This is just incase. Go into UPnP fowarding and enter in the same stuff you did for Step 4.
Step 6: Now logout of your router config. Unplug your router and modem from the power, then plug in the router 1st, wait 30 seconds. Then plug in the modem and wait at least 2 minutes. If you don't do these hard restarts it might not work!
Step 7: Restart your Xbox and go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN. If not, sorry. You can just undo all the settings we changed, you can just uncheck enabled on the port fowarding. or if you want to restore your router to the factory defaults just push the reset button on the back of it.
Once again this may not work for everyone, but it worked for me and my friends, so good luck.
Feb 27, 2011 | Video Game Consoles & Games
Password
you will need the password to login to change anything in the router like port fowarding or reset or just firmware upgrade
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Belkin (F5D7231-4) Wireless Router
I am trying to get set up so I can use SlingPlayer on my computer.  I called their help support.  He did a lot of checking.  He said to contact you all and have you open port 5001
To do this, you need to acess your router by going to 192.168.1.1.
It will ask you for a password and username, and if it is set to the default password and you do not know it, you can get it at routerpasswords.com
After, look for a Port Fowarding or Port Ranging menu.
Input 5001 for Start and End and set it to both TCP and UDP.
after save and exit, and you are done.
Dec 29, 2008 | Computers & Internet
Port fowarding
fixed the problem by typing in the address bar the make and model of the router and portfowarding EG: netgear nbm814x portforwarding
looked at the list of sites that had info on it a picked one and read carfully the information. did the portfowarding and set up a static ip address
works fine now
May 19, 2008 | Computers & Internet
Port Fowarding
Here is a listing of programs and how to forward them for your router.
PortForward
Feb 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Port fowarding
open your browser on the address bar type in http://192.168.1.1
if you get prompted for user name and password your good to go
type 'admin' in the password box and your in
UNLESS you specified a different log-in and router IP in this case you will have to do a factory reset, this will erase all your setting back to default, then you can log-in
Thanks for rating
Jan 11, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Port Fowarding Issue
Hi Noshhit,
On your Xbox, go to the dashboard, move along to the 'system' tab (the furthest right tab), then go down to "Edit Settings" and you will see your IP info in basic settings. Your Ip is there.
Good Luck!
Jan 07, 2008 | D-Link AirPlus DI-524 Wireless Router
Port forwarding
Please find the URL below which will help you getting the port forwarding done.
http://portforward.com/english/routers/port_forwarding/ZyXEL/Prestige660R-61/default.htm
with regards,
TPV
Dec 20, 2007 | Zyxel Prestige 660R Router (91004397002)
Computers & Internet Logo
49 people viewed this question
Alun Cox
David Payne
David Payne
