Question about Toshiba Satellite A10-S129 Notebook
I have a Toshiba Satellite A10-S129. It was working with 256 MB (2 x 128 MB). I wanted to upgrade it to 512 MB (2 x 256 MB). I bought 2 new 256 Modules and when changed it and turned on screen has never come up. I tried turning on and connecting to a desktop monitor and did not work. When I turn it on I see all light in the front panel lighted and listen a sound like the fan is working but screen never comes up. Thanks
    Problem Solver:
  • 13 Answers
If it works without the upgrade Go to crucial memory test .com that will scan your computer and tell you what upgrades it can handle
Posted on Mar 20, 2011
  • Toshiba Master
  • 32,281 Answers
If you get several beeps then there is a video problem. The video card uses shared RAM (part of the main RAM) and if the RAM is faulty the laptop won't boot up.
You might have incompatible RAM, try to use the same make and speed RAM as the original.
One of the RAM modules may be faulty.
Try installing one 256Mb RAM module then boot up the Toshiba, if it works the try the other RAM module.
  • 281 Answers
According to Crucial's website, (crucial.com) your laptop can support up to 1 GB of PC2700, DDR RAM; since it's a laptop you will want a sodimm. After disconnecting power and removing battery, (ALWAYS DISCONNECT POWER AND REMOVE BATTERY WHEN ADDING OR REMOVING BATTERY) I would recommend that you remove the two modules, inspect them and make sure they are PC2700 DDR modules, It doesn't sound like your system is able to recognize the RAM you installed. This could be either due to a compatibility problem or perhaps one of the modules is bad. If they are the correct part, install one module in slot "a" (usually they are marked, if not disregard, and choose one slot.) Connect power and test. If it works, repeat with the other memory on the same slot. If it doesn't switch it out and put that one aside for now; if the other one works, then you probably have a bad module. You can pursue a warranty claim or at least ask for an exchange on it.
If neither one works, you either have an incompatible speed (pc3200 does not always work reliably in all units), or although unlikely, you could have 2 bad modules, or an incompatible style (like error checking or registered modules.) Once again, I would contact the vendor and make them aware of the problem; if they were purchased recently you should have no problem getting an exchange.
Where is the cmos battery on a Toshiba laptop model a10-s129
Please refer to the below URL to download the Service Manaul of your notebook where you can find the requested info:
http://www.retrevo.com/support/Toshiba-A10-S129-Laptops-manual/id/614ag314/t/2/
May 25, 2010 | Toshiba Satellite A10-S129 Notebook
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Display is distorted with weird vertical lines on toshiba satellite A10-S129
This sounds like the LCD has been damaged. It will need to be repaired.
May 06, 2009 | Toshiba Satellite A10-S129 Notebook
Upgrading system ram
This computer supports up to 512 MB of RAM, so you can add another 256 MB of RAM....
Apr 10, 2009 | Toshiba Satellite 1805-S274 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Has anyone upgraded the memory on a toshiba satellite 1900-603
it should be beneath the slot u installed the memory on both slots are next to each other one on top the other beneath i fu dont find it tell me exact model number to help u more in this
Feb 24, 2009 | Toshiba Computers & Internet
I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
In short.... yeah, 512k is the max.
Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
Jan 24, 2009 | Toshiba 2405-S221 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Maximum Ram upgrade?
this is the link
http://www.memorystock.com/memory/ToshibaSatellite2400103.html
In this link u have following details
1)Maximum capacity RAM Information Available
2)Toshiba Laptop Memory Installation Video
3)Laptop Memory SODIMM Installation Guide
If you r Satisfied with information provided from my side please give me good ratings thanks
If u require more information search in google
Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
Toshiba Satellite A10-S129 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
