Question about Garden
What mix to use on makita rst210 trimmer when adding oil to the fuel
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
bozcro
  • 867 Answers
SOURCE: 2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Posted on Jul 24, 2009
  • 2468 Answers
SOURCE: Makita RST210 grass trimmer not idoling and backfiring
your muffler has gotten full of carbon from the oil/gas mix you use and now theres too much back pressure and needs to be removed and cleaned or replaced,also while its off clean out the carbon deposits on the reed valves at the exhaust port
Posted on Mar 08, 2010
SOURCE: I have a gas operated 31cc Craftsman model number
i have a craftsman 31cc weekwacher trimmer and have bought an after market head to put on it so that i don't have to wind string on to the spool all the time. the new head has inserts for like 10" plastic. i don't know how to get the head off to bolt the new one on. can u please help me
Posted on May 26, 2010
SOURCE: gas/oil mix john deere C1200 trimmer
50:1
Posted on Jul 13, 2010
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
My RST210 2 stroke petrol strimmer won start it has a spark at the plug also the plug is flooding so fuel is getting through but non start ? Great full for any ideas
Often it's the easiest thing that stump us. Try changing the spark plug first. Sometimes a spark plug just won't fire under load, i.e., while it's in the cylinder but will spark if you have it removed. There are checkers for this, but it's a lot less expensive to just replace the spark plug. Do that first and let me know.
Sep 28, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
One litres to a gallon
One US gallon is about 3.79 litres. One imperial gallon is about 4.55 litres.
Jul 20, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
Makita rst210 (brand new). Engine runs well but cutting head won't spin. how do you release/apply clutch?
I would like to suggest that you follow the warranty instructions for this machine and go about getting another unit. I'm sure if it is a Makita, that there is a valid warranty for it. The clutch is centrifugal and if it is not working, much disassembly is required.
Jan 08, 2011 | Garden
Having problems starting Makita strimmer. There is quite a lot of smoke coming out and then it stops. Have looked at spark plug -clean, and cleaned air filter. Could the problem be the petrol and oil mix.
Use 50:1 gas/oil with a GOOD QUALITY 2-cycle low-ash synthetic oil.
Remove the muffler and check the spark arrestor isn't partially blocked.
With a clear muffler, and the mix as described, there will be hardly any smoke at all.
May 09, 2010 | Black & Decker String Trimmer Cordless 12"...
Mar 08, 2010 | Garden
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Garden Logo
337 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
