Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How to install clip spring # 732-0525 - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How do you refit distributor cap clip to distributor when it comes of?
There are usually two spring clips that hold the cap on, or alternatively it will be bolted on. If it keeps on coming off, then I assume your must have the spring clips. Make sure both are properly in place as it should not come off if they are installed properly. Sometimes one of the clips will break and there will only be one.
Jul 03, 2016 | Cars & Trucks
I need to installhow to install a new deflector on Craftsman mower model 917273130?
Very simple. The 6 inch or so pin that holds it on is retained by a clip on one end. To remove clip use a pair of pliers. If you work steadily and carefully you will be able to reuse this clip. After removing clip, pull the pin out. Old deflector and spring be removed now. To get the spring right you have to try it in position before installing it. Just remember that the spring is holding the deflector down so when you are done installing, when you pick up on the deflector there is pressure holding it down. Don't put the pin clip on until you verify the spring force is correct because getting that spring clip off is the Hardesty pay off the job.
Oct 11, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I replace the clip-spring on the duet sport dryer?
Here is how to install the 8066208 clip-spring in the lint housing of the duet dryer. Hold the clip with the curved end facing down towards the ground. Now insert the opposite flat end of the clip through the slit in the lint housing. Continue to push the clip inside the lint housing until it stops. The flat end of the clip will slide to the bottom of the housing. There should be about an inch and a half of the clip showing when all finished.
Feb 23, 2013 | Maytag Parts Maytag 8066208 Dryer...
How to re install oven door
There are two pieces of metal that are inserted into the hinge slots on the body of the oven, the spring (upper) and the hinge. Before you can re-install the door, you have to clip these two together by laying the door handle side down and then using all of your body weight to push down on the spring arm, using gloves and a wadded up rag to soften the impact to your hands, and then clip the two pieces of metal together using the little hinged clip on the hinge piece and the slot on the spring piece. When you've clipped these together on both sides, lift the door and insert the metal pieces into the two respective metal slots on either side of the oven body. when they're in as far as you can push them, use a flat edged screwdriver to release the clip and close the door. Good luck, it may take a couple of tries and be careful of the spring, because it can snap back and hurt you if the clip comes off prematurely.
Feb 20, 2011 | Thermador PGR366 Gas Kitchen Range
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Tecumseh carb 631827. Took it apart, cleaned everything and re-assembled. The inlet needle will not let gas into the bowl. I took the needle out and the bowl filled up with gas. Why is the inlet needle not...
Hi I am Kelly, I realize this post is nearly 10 months old. I am answering it now because it appeared after I made another post. Hopefully the repair information can be used by others.
Using this link:
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CTEC%5Cimages%5Cimages%5CCA01%5C1.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=34
Item 31 (spring Clip) is what is used to lift or lower the float needle. If the spring clip was bent or installed so that the spring was on top of the float needle head vs cliped to the recessed area of the float needle you will have the symtom you described. Usually you do NOT have to bend the spring clip to install it correctly. However, if it was bent during installation you will have to shorten the distance of of the spring clip horse shoe fold so that it lowers the float needle when the float is lowered.
See the picture on page 40 of this manual for the correct spring clip installation view: http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_CARBURETOR_TROUBLESHOOTING_AND_IDENTIFICATION_GUIDE.pdf
One other thing to consider is that if the float needle seat is not pressed all the way into thebody you will have the symptom you described.... i.e no fuel flow with float in the lowered position.
Good luck,
Kelly
Dec 31, 2010 | Tecumseh Enduro Horizontal Engine 5 HP...
My lowbeams don't come on for my 2005 Volkswagen Jetta. (Although the highbeams do come on.) I just discovered this tonight. Could this be a burned out fuse or other electrical problem?
Headlight
Bulb Replacement
To Remove:
  1. Release the spring clip and remove the protective cover from the rear of the
    bulb.
  2. Disconnect the electrical connector from the bulb.
  3. Remove the spring clip and remove the bulb from the headlight housing.
To Install:
CAUTION
Do not touch the glass portion of the new
bulb with bare hands.
  1. Insert the bulb in the housing.
  2. Secure the bulb with spring clip.
  3. Connect the electrical connector to the bulb.
  4. Install the protective cover on the headlight assembly.
Oct 29, 2010 | 2005 Volkswagen Jetta
Change headlight bulb
Removal & Installation Bulb Replacement To Remove:
  1. Release the spring clip and remove the protective cover from the rear of the bulb.
To Install:
CAUTION
Do not touch the glass portion of the new bulb with bare hands.
Headlight Assembly
Jul 16, 2009 | 2004 Volkswagen Jetta
Remove and replace rear brake shoes on 2004 honda accord
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Does not spin
for everyone except 'overseer'
the coupler can be purchased at a local parts store
'Kenmore motor/gearbox coupler' will get it for you, there is only on for all the models.
it is an easy fix
  • unplug washer
  • remove trim ends of control panel
  • remove phillips head screws from bottoms of control panel under where trim was
  • slide control panel forweard & up about 1 inch, then flip over the back of the control panel, do not dislodge the air hose
  • remove brass clips in rear corners of top with screwdriver, remember how they fit
  • unplug lid switch connector
  • lift body 1inch and slide forward to remove
  1. front center is the motor pump and gearbox
  2. do NOT disconnect hoses
  • remove spring clips holding pump on to motor shaft, note where they go for reinstall. there may be a lock screw in the top right clip.
  • swing pump to the left and use a string or bread bag tie to hold it out of the way.
  • remove spring clips holding motor to gearbox shaft, note where they go for reinstall. there may be a lock screw in the top right clip.
  • heave ******* motor, to separate the coupling
  • remove coupling halves from gearbox shaft and motor shaft and discard.
  • using a wooden dowel and hammer, on the center of the new coupling halves, drive them onto the motor and gearbox shafts, (dont hit the fingers, they break, note the new couplings have metal centres to solve ongoing problems.)
  • rotate gearbox coupling, 1 up 2 down
  • rotate motor coupling, 2 up 1 down
  • install rubber shock pad on gearbox coupling
  • install motor on shock pad
  • reinstall spring clips and lock screw if fitted (bottom first, rock the motor on rubber shock mount to ease spring clip installation)
  • rotate motor shaft to align with pump input
  • install pump on motor shaft
  • install spring clips and lock screw if fitted
reinstall body in reverse order
it takes less time to do the repair than it takes to type this
Sep 29, 2007 | Kenmore 15864/15862 Top Load Washer
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
258 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
