Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
I cannot get the enable blue tooth option to switch on. It used to enable when I took the battery out but now not even that works My phone is a blackberry pearl flip 8220
Take it in to the dealer, it is a COMMON problem with the blackberry flips, out of 10 people I know that have this exact phone, 6 of them have had to be returned and sent away for repairs, (which in turn got them a new phone.) That is if you have a warranty. If you don't have warranty, then you have to pay for it to be fixed. It just depends on how bad you want the bluetooth...
Posted on Mar 22, 2011
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
The bluetooth cannot be switched on. It cannot be enabled.
Hi, problem can be solved. First, restart the phone see if the blue tooth will come on.
Also if the blue tooth doesn't come on,that means blue tooth is corrupted by virus.
You will need reset the phone or flash it.
Take care.
Oct 09, 2010 | Cell Phones
How do i send a photo from lobster 575 I have taken a photo on lobster 575 how do I now send this to someone on my phone list. I don't seem to be able to actually send the photo.
hi,
if you have taken the photo, press the option button, go to send, you will be given option to send through blue-tooth,infrared or mms.
if you send through infrared or blue-tooth switch on the infrared or blue tooth of the of the receiving phone.
after some seconds the picture will be send to the phone.
thanks for using fixya.
May 26, 2010 | Lands Phones
Switch off bluetooth
Go to
Menu - applications - blue-tooth - Tap on the round disk with the phone icon to switch off or on.
If you see the blue-tooth options in the list view then it's the first options.
In-fact you will see the option running right to left.
Hope it helped.
Apr 27, 2010 | Samsung SGH-S5230 Cell Phone
Hi everyone. i just bought samsung link cell but i dunno how to use the bluetooth here. can you help me with this? actually, i tried to but the only command here is copy/move but it only copied/moved to...
before purchasing the phone did you ask if the phone has a blue tooth?.Because from the description you said your phone only send via multimedia message or text.
For a phone to have a blue tooth, in the send options blue tooth phone has three option which are multimedia message, text and blue tooth.
This is just an advice, if from where you bought the phone from they told you it was a blue tooth phone, you can still go back and make complains of the phone and tell them it is not a blue tooth enabled phone.
Have a nice day.
Mar 15, 2010 | Cell Phones
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
How to connect between blue tooth with samsung phone ?
With a samsung cell phone press the MENU button then scroll to SETTINGS then scroll to BLUETOOTH. Once there select the option ENABLE and turn on bluetooth then sync and your set. Also make sure that your blue tooth is compatible with your phone.
Dec 07, 2008 | Lands Phones
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
205 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
