Question about Sony Bean MP3 Player
Charger error message - Sony Bean MP3 Player
    Problem Solver:
  • 14 Answers
The charging/connection port is damaged or the battery is simply burnt, you either have to buy a new battery, and if that doesn't work, it get's worst, buy a new mp3.
Posted on Mar 20, 2011
Why does my Nokia phone say "charger not supported?
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
Jun 01, 2011 | Nokia 2626 Mobile Phone
Battery will not charge.Message reads "temp error charging stopped"
If you haven't already, try replacing the battery. If the error persists, replace the charger or test with another known, working charger. Else, the phone charging circuit must be damaged and the phone must be sent in for repairs or replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 16, 2011 | Cell Phones
Dear Sir, I own K 790i, whenever i put for charing i get an error message stop charging error, i have tried charging through differenct sockets still error message continues but when i charge through my...
If its charging on your computer,then the problem is the charger itself.
The first thing to do is try to check you charger and its terminal,pins might not in align or corroded,otherwise buy original sony ericsson charger.Also check the charging terminal of your phone. you can clean it using brush or a pin and scratch each portion so that the power voltage will some it.
Apr 04, 2011 | Sony Ericsson K790i Cellular Phone
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
Dust on drum error message. How to clear
On most fax machines a Dust on Drum error simply means that the drum unit needs to be removed and the charger cleaned by sliding the small built in charger cleaner back and forth but be sure to place it back in it's home position or your received faxes and copies will have a blank line thru them. See your operators guide for more details.
Aug 18, 2009 | Office Equipment & Supplies
Data cable error message
please give me data cable error number
Jul 26, 2009 | LG Dare VX9700 Cell Phone
Charger Error Pop Ups
dear,
this issue directly related with the charging circuitry... the issue can either be with the charger itself or majorly with the charging ic ...
i had faced this problem with the chinese mobile phone but this can be either with the chinese model or can be with the other...so check the both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
Jul 18, 2009 | Dual Electronics CECT P168 Cellular Phone
SUBJ: JVC CAMCORDER DVL805. Error message...
oh me MINE did that exact same thing UNIT IN SAFEGUARD.. grrrrrrrrrrr.. YEP NEW CAMERA TIME.. sometimes they tell you that those battery cahrgers will work but it all really just defects them
Jun 11, 2009 | JVC Cybercam GR-DVL805 Mini DV Digital...
Charger conectivity
for black and white sidekick, right? if so, then it sounds like its need to get a new charger to give it a better connection. it has been ages since its outdated a long ago.
Ive never heard of that error message said that before. but, yeah..try use another charger and see if it makes the error message go away.
good luck and let me know.
Mar 07, 2009 | T-Mobile Sidekick
Sony Bean MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
