Question about AOC FOVI F19S Monitor
Hi! I want to remove the OSD attention from my monitor. How do I manage this? It's necessary to me remove this attention pop out.
  • 281 Answers
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.Hi! I want to remove - tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
Posted on Mar 20, 2011
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
How do you get a osd lock out pop up fixed?
hi i have HP F2105 monitor. "OSD lock out" pops every 5 sec. what shoud i do? plz help
Oct 18, 2010 | HP Computers & Internet
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
OSD + GNR 19M1 LCD screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Dec 22, 2009 | GNR 19M1 19" LCD Monitor
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Aug 22, 2008 | Computers & Internet
The OSD button has gone faulty.
The button will need to be replaced , or it might just need spraying with a contact cleaner like RP-7 or WD40.
Both solutions will require the removal of the front cover to access the button.
Jun 06, 2008 | Philips 190B6CB/27 19" LCD
AOC FOVI F19S Monitor Logo
199 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
