The burner head inside the tube of the 40,000BTU/Hr does not put out a constant flow of flame...After repeated wire brush cleanings. The result is unburned gas and a unsafe operation. Do I need a new burner, or could it be a regulator. I have always used this Dyna-Glo Heater in my shop, which is indoors and out of the elements. Thank You for your time. Steve T.
    Brigadier General:
  • 4,736 Answers
Since the burner has been cleaned with no improvement in the problem. I suspect that it's an air to gas mixture problem. Dust may have clogged the air intake valve.Or the Burner Nozzle may be partially clogged. Here is a link to an Owner's Manual for a Dura Heat Heater that is the same as yours, that may be of some help. http://www.worldmkting.com/documents/GFA2010Manual.pdf
Posted on Mar 20, 2011
Flame is high on left back tube of Burner Assembly
The burners need to be removed, cleaned and inspected. Any obstructions on the burners need to be thoroughly cleaned with a wire brush. changing burners to different compartment and still having the same problem in the original chamber, could be a defective heat exchanger.
May 19, 2014 | Goodman GMS90703BXA Heater
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
I have an older natural gas furnace that has a manifold and 4 burners. I clean & inspect it myself every year. This fall I removed & cleaned each burner as usual. I'm now experiencing something...
You need to reclean the burners every little hole needs to be cleared of rust the only thing that can cause fire in the tube is the gas is not getting out. Try scrubbing with a wire brush then use compressed air to blow out each opening in the burner.
Dec 06, 2010 | Heating & Cooling
To day I was using the oven it was working ok but suddenly it shut off and I was trying to turn on the oven it was shutting off again and again
First of all check your gas connection, the flow to the range. If Ok then there is dirt accumulation to choke the AIR FLOW into the burner. Use a tooth brush with some good degreasing spray to remove the burner, clean off weell so that the seating of the burner to the bottom stem is fitting. if not repeat , use a soft water paper if required to achieve this -- due to constant wearing.
If the gas flow is not establised now then you must clean the regulator jet. Remvoe the regulator, use a good air jet to spray out dirt or crusting and makea clean passage.
Once the gas flow is establised with the burner in place with the work done earlier, you must get a good flame.
Sep 17, 2010 | Magic Chef 31000 Gas Kitchen Range
Good pilot,but no cross flame
cross over tubes are probably plugged you have to pull the burners and clean cross over tubes.
Jan 13, 2010 | Heating & Cooling
Low heat
clean burner holes with wire brush real good... if one burner lites and the next lites,but the first burners flame drops-replace Regulator. Its the hose that connects your tank. tapping metal housing with plyiers the next time it does it will show the plastic wheel inside housing is stuck and cannot allow the gas to flow
Dec 31, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Dec 12, 2009 | Heating & Cooling
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Mar 21, 2009 | Weber Genesis Silver B Grill
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
