Question about Sanyo Microwave Ovens
Glass tray Where can I find a revolving glass tray to fit. I live in Brampton, Ontario.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • 100 Answers
Have your brand and model number, then check with...
www.microwaveglasstrays.com
Posted on Aug 14, 2008
I have a Sharp carousel R 9330. I need the 15 inch revolving clear glass tray that goes with it. Mine broke after over 15 years of use. Where can I find a glass tray for it?
That is part number NTNT-0036MRF0 (those are zeroes, no ohs) and you can order it from Encompass here.
Jul 08, 2011 | Microwave Ovens
Metal propeller still turns but plastic three arm proellers is broken therefore Glass tray does not revolve
you can order a new turn stub from thermador at there web site they cost around $ 15 and just pull out and push back in
Feb 15, 2011 | Thermador MBBS Microwave Oven
Can you trun off the turntable
Hello paula.... there is no switch or other easy way to turn off the turntable. What you can do is simply remove the glass revolving tray and ring and use the microwave with the turntable removed. Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Sunbeam SMW777 Microwave Oven
Hi, we have a Bosch HMT8656GB integrated microwave (fitted in 2007) and in the last 2 weeks or so, the glass tray on the bottom of the microwave has stopped going round when the machine is in use, however,...
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Feb 04, 2011 | Bosch HMT8656GB Microwave Oven
Hi , in ur panasonic microwave glass tray is not revolving plz suggest what to do? thanks
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Feb 24, 2010 | Microwave Ovens
I have danby microwave m# dmw 1147SS the glass centre dish slipped out and broke I am currently looking for a replacement Please advise. sherry I live in brampton Ontario
Contact Danby Customer Service US / Canada here.
Please let us know if they do not help you.
Jun 15, 2009 | Danby Microwave Ovens
Which microwave has no turntable?
look at the features the new microwaves have. alot of them have a button to turn the turn table off
Jan 31, 2009 | Microwave Ovens
Microwave Ovens Logo
74 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
