Question about M-Audio Producer USB Microphone with Session Recording Software
My Dell Inspiron 545 computer makes a constant low hum. When I record audio (my career), it picks up on the mic. What can I do?
  • 24 Answers
Get a much longer USB cable and distance yourself and the mic from the computer.
You could also try putting some soft services near the computer so that the noise doesn't travel.
Posted on Mar 20, 2011
Audio buddy buzz
Background 50 or 60 Hz buzz can be radiated from nearby wiring or conducted. Grounding is important but that can also be a cause. I suggest you search accidental hum loops.
Poor or faulty power supply regulation or smoothing can inject a mains hum into audio. This would need checking with an oscilloscope which could also be used perhaps to help search for the source.
Radiated hum can be picked up and injected into high gain amplifier inputs and long leads, poor screening and impedance mismatch can make things much worse.
I haven't helped much but I hope I have given you food for thought and further research.
May 30, 2017 | M-Audio M Audio Audio Buddy Microphone
Reinstall my windows vista and now i cannot get the mic to work
go to control panel, then sound. On sound, pick "Manage Audio Devices." You should get the below window. Click the "Recording" tab then right click the window. You should get a short menu that includes "Show Disabled Devices." Pick that, and then enable the mic. OK?
Nov 22, 2010 | Dell Inspiron 1501 Notebook
My Dell Dimension E510 cannot pick up any voice recording from my various mic inputs. I have fiddled with volumes of each respective input (line in, rear mic, mic jack) to no avail, and when I try to use...
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
Mar 09, 2010 | Dell Dimension™ E510 PC Desktop
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
My dell inspiron 1525 has a built in disarray mic but computer does not detect it??I've tried downloading the sigmatel driver but it says object not found. The webcam center does not give me any options...
Uninstall and reinstall the audio drivers. That should fix it. Also check in Audio/Sound properties in Control panel under Recording and check if the Array mic is detected and set as default. Try downloading "http://ftp.us.dell.com/audio/R171786.exe"
May 18, 2009 | Dell Inspiron 1525 Notebook
Sound is ok i hv mic problem
If you install the correct drivers, the audio device should work fine. That includes the microphone if present. Check your sound recording settings in Vista to make sure all the device selections, recording levels etc. are set okay.
Then try recording with the Vista sound recorder to verify.
Apr 05, 2009 | Dell Inspiron 1521 Notebook
The Internal Mic In My Dell Inspiron 1525 Isnt Picking Up Sound??
You need to set the internal mic as the default input device. To check this Right click on the sound icon next to the time and select Recording properties. In the Recording properties right click on Arrey Microphone and select set as default. If this does not help. Uninstall and reinstall the sound drivers. To uninstall the sound drivers click on start and type DEVICE. Open device manager from the results and then look for sound devices. Click on the Plus sign next to Saound and audio devices. Right click on the SigmaTel entry there and select uninstall. Put a check on remove this driver from the computer. Once done restart the computer and go to support.dell.com and click on Drivers and Downloads. Enter your system service tag and download the Sigmatel audio drivers and install them. Check if the MIC works after the restart. If the Arrey microphone is set as the default and you have uninstalled and resinstalled the drivers and it does not work in MSN try recording with the Windows sound recorder and see if it works there. To open the sound recorder click on start and type SOUND. Open sound recorder from the results. Incase the mic does not record even in the recorder it could be bad or have a loose connection. If in warranty call/chat with the Dell technical support. If the warranty has expired consult a local computer guy.
Mar 29, 2009 | Dell Inspiron 1501 Notebook
Microphone on Dell Inspiron 600M PC Notebook not working
If your Inspiron 600m had a mic that you used in the past and it is no longer working, please try to press the mute/volume down/up buttons near where the whole of the mic is located.
If, after trying the above, 1 or all 3 buttons do not work, the problem is with the board that is right under the power button (small 2-3 inch length circuit board). It is not making full contact on its connector below. If you put pressure on it (just above the power button) it will all respond. I had the same problem on another 600m laptop.
Feb 23, 2009 | Dell Inspiron 600M Notebook
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Dec 15, 2008 | Dell Inspiron 1521 Notebook
M-Audio Producer USB Microphone with Session Recording Software Logo
194 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
