Question about Harley Davidson 426290 AM/FM Radio
With the key off the radio back ground light stays on Why
  • Iron
    Iron Mar 20, 2011
    Can you tell me if this was recently installed? Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
You mast likely have an internal short in the radio causing the illumination control line to stay active. This has the possibility of draining your batteryand eventually doing some damage to the radio.
For repair options on an 06 or newer, contact Iron Cross Audio
www.ironcrossaudio.com
Posted on Mar 20, 2011
Turn key off and removed. Power stays on radio ,heater.
Hello? It sems that the wiring is not done properly. Make sure that the radio wiring is done correctly. We have 3 wires that are very important when it comes to radio wiring. We have vcc,acc and ground. Vcc has to connect to battery direct, this helps keep radio memory on all the time. acc goes to acc and this switches radio on and off when you turn the key. Ground goes to earth. The wiring harness color code depends on different radio makes and car makes as well but a professional should help you with this.
Nov 16, 2016 | Cars & Trucks
Sunfire would not turn over after parking
check all of your grounds a bad ground or a shorted ground can trigger stuff to go off at random plus if it started right up when you got the car jumped then yea it has to be a bad ground like i said check all of your ground wires and update me with the situation
Oct 18, 2013 | 2000 Pontiac Sunfire
2001 Chev Malibu. Turn key on to start car, won't start. No warning lights on no lights on gauge panel. Radio works, dome light work.
check the ground leg to your engine.. it runs off the neg. battery terminal. will connect to frame and engine.. pull it off, wire brush it put it back.. you radio will work, 'cause it draws much less current, and is grounded in dash.
Jan 11, 2013 | 2001 Chevrolet Malibu
Wend i key the radio some time my receive stay stock on s9 then i press the ptt again and go back to normal s3 why is that.
Either a dirty meter, erratic ground problems, high swr's
internally on the meter, put a few drops of wd40 on the pivot point...
Mar 03, 2011 | Galaxy Radios Microsystems DX94HP CB Radio
When Mic is keyed TX illuminates but no green nand red bars light up. Anh help appreciated.
Get a SWR-PWR meter to put on the line between the radio and antenna to see what it is doing.
Feb 16, 2011 | Cobra 19 DX IV CB Radio
Does the rx/tx green light stay on all the time? Cobra 29LTD
Yes the light will stay on and change when you key the mic
May 07, 2010 | Cobra 29 LTD CB Radio
When I turn on my headlights, my radio goes dark and plays static. The domelight and floor lights go on, my dashboard lights don't work, and my tail lights don't work. If the headlights are off, the radio...
It sure sounds like you have a case of "sneak circuits"
These are usually caused by a bad ground somewhere and something is "grounding" through the light bulbs.
Have you changed any wiring or installed a stereo or some other accessory?
You might use a jumper wire and ground the dash and other areas to the negative battery post as a way to find the culprit.
Apr 30, 2010 | 1991 Chevrolet S-10 Blazer
All the wires are hooked up to my radio correctly but when i crank my car or turn the key back the radio doesn't come on. then when i cut the park lights on the speakers make some kind of flickering noise...
I think you need to check your power wires to your radio. This is a common mistake. There are several power wires to deal with. One wire stays hot to keep the clock and radio presets working. The second is Hot when the key is turned on. The third is hot when you turn on your lights for instrument lighting. If you connected this wire for your power source, You would have this problem you are describing. If it's wired correctly, Check the ground wire to the radio. Hope this helps.
Mar 13, 2010 | 1995 Buick LeSabre
Harley Davidson 426290 AM/FM Radio Logo
82 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
