Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
  • 42 Answers
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Posted on Mar 21, 2011
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
https://apwagner.wordpress.com/2008/.../22/5-common-freezer-problem...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
askville.amazon.com/freezer-suddenly-frosting/AnswerViewer.do?...
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ...
www.shopyourway.com > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
There is a light in my freezer. but, it doesn't get cold
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are locked into the defrost mode. This is where every 8-10 hours your unit will completely shut down except for the lights. At this time your defrost heater turns on for 20-30 minutes to defrost the evaporator (Cooling) coils in your freezer.
You can manually turn your unit back on, until you get a new defrost timer. If you have a up right freezer your defrost timer is in the lower back. It is mounted on a metal plate.
With a flat head screw driver turn the stem slowly one click at a time until your unit turns on. Once a day repeat this process to put your unit back into defrost until the timer is replaced.
If you have a top freezer the defrost timer is located on the top of the fresh food section on the left. Do the same thing. The cost of the timer is about $30.00.
Send me your model number located on the side front wall of your fresh food section and I will proved you with the part number and walk you through the repair.
Feb 19, 2015 | Freezers
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
GE UPRIGHT FREEZER NOT FREEZING.
Hello Mary;
You are locked in the defrost mode. About every 8-10 hours your freezer will go into a defrost mode for 20-30 minutes. This is where all of the components will shut down except for the light.
You have water on the floor because your condenser fan and compressor is shut down.
You did not provide a model number. Your model number is on the inside wall of your freezer near the top. So, I can only guess.
Lets take your freezer out of the defrost mode. In the lower back on the left hand side is your defrost timer (This may also be in the lower front depending on the model). Following is a picture of what a defrost timer looks like.
The time is mounted on the back of a plate and held on with two screws. The plate has a hole through it to give you access to the round knob on the left. The knob has a slot in it. With a flat head screw driver turn the knob clockwise. You will hear a click. Turn one click at a time until the freezer turns on.
The timer cost about $20.00. You can replace it yourself. Unplug the freezer. Unscrew the timer. Remove the connector on the right.
You need to replace the timer or you will have icing problems.
Send me your model number and I will tell you what the part number is.
Feb 17, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Our frigide is defrosting water into the bottom the fridide the lays in the cavity under the crisper and after a while(8 or 12 DAYS)RUNS OUT ON THE FLOOR
you have a clogged defrost drain. when y our unit goes into defrost, the water that is supposed to go down a tube from your freezer down to the bottom outside of the unit, into a pan to evaporate, instead is going into your fridge etc. This drain needs to be cleared. I would not recommend doing it yourself, you may cause further more expensive damage.
Refrigerator FAQ and Tips
Mar 21, 2010 | Electrolux Freezer Kelvinator Single Door...
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
New fridge is creating icecles on the top and door inside of freezer.
This problem can mean outside air is getting in. Look at your door seal, is it cut or crimped or out of its sattle. Another pos. problem is defrost. During the defrost cycle heators turn on and cause steam inside to rise up and collect at the roof, then refreeze, check the back panel for a good tight fit inside, is it bent or warped? That will let out the steam vapor that should stay right at the evap coil.
Jun 29, 2009 | Frigidaire Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Dec 03, 2007 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
109 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
