Question about Car Audio & Video
I need to remove the combination radio/dvd/cd/navigation/sirius satellitte in order to bench test because it stopped working...no sound
  • Car Audio & ... Master
  • 4,981 Answers
Insufficient information so please post more details
Quote the make + model plus the make of car it is fitted into
Posted on Mar 20, 2011
No sound on AM/FM but Sirius is fine
I would look at the antenna connections ... you will need to remove the unit from the dash to get to the back of the radio. [Google removal of that specific radio for your vehicle]. You may be able to get your hand up under some dash boards to reach the back of radio?
The antenna conception is typically a round coax conductor that goes to a plug into the back of the radio.
Try moving the plug around while radio is on ... if you get signal pull out connector and clean contacts with rubbing alcohol. Test again and reinstall.
Hope this helps!
May 04, 2016 | 2012 Dodge Grand Caravan
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
2009 dodge ram , fm,am,cd,all work fine on radio. but when I hit satelite radio it shows channel 184 and there is nothing.
Is there audio on 184? It sounds like it just needs to be activated. Call Sirius with the SID #, and they can send a signal. Sirius' # is 888-539-7474
Jun 04, 2011 | Sirius Satellite Radio Sirius Starbase...
Can i play mp3
Yes it does.....I have included a full list of specs for you for this model
  • DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
  • fits double-sized (4" tall) dash openings
  • motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
  • plays CDs, CD-Rs, CD-RWs, DVDs, DVD-R/RWs, and MP3 discs
  • GPS navigation (includes GPS antenna and map DVD-ROM)
  • City View mode - 3-D maps that render accurate representations of specific buildings in many cities
  • 6 million points of interest (hotels, restaurants, gas stations, etc.)
  • customizable route preferences
  • separate CD and DVD slots
  • five soundfields: cathedral, club, concert, live, theater
  • 9-band parametric EQ
  • 5 preset EQ curves
  • SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
  • compatible with Eclipse HD Radio™ tuner
  • CD changer controls
  • audio/video input
  • rear-view camera input
  • audio/video output
  • 5-volt front, rear, and subwoofer preamp outputs
  • AM/FM tuner
  • 6 FM/6 AM presets
  • warranty: 1 year
Oct 08, 2010 | Eclipse AVN5500 Car DVD Player
I have no sound. Radio is on, CD player works
The antenna lead you are using to turn on your amp is dropping out when your cd is coming on try using the blue/white stripe wire instead of the blue for turn on.
May 09, 2010 | Metra CHTO-02 Chrysler Pacifica 04-Up...
I have a sirius ready cd player installed in my jeep. I was wondering how I get sirius radio..when you scroll through Cd,radio, aux , there is sirius so i dont think i need another radio...but i dont know...
Looking at the user manual on page 13, you have to purchase and connect the XMD1000 module to in order to get the satellite radio service. If the module is installed, you'll get a display telling you to sign up for service.
Feb 24, 2010 | Panasonic CQ-C7301U CD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Do I need a Sirius radio antena for a MBB219
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Jun 03, 2009 | JBL Mbb 218 Cd Radio
Question about sirius radio for kenwood cd player
You can try it, but I think you might need a media expander/controller. I see some going for around $100 on Ebay. It allows you to add and interface many component to your deck. But make sure the deck ready to control it. You can tell by the label on the deck(Ipod ready, XM ready, Sirius ready, Changer ready....ect). Goodluck.
May 09, 2008 | Kenwood KVT-717DVD Car DVD Player
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
