Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
74pvp-2 7.4 Gpm has a continuous flashing 13 error code even when remote is off! It only goes off when i shut the power off. I checked the burners but they are clean and i think the vent may have allowed water condensation into the machine. Anyone have any experience with this?
Rheem tankless do-it-yourself troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Posted on Mar 22, 2011
Code c7 13
1) Copy following link for troubleshoot resources including error codes:
2) Unknown if this is new install or older unit with new problem
This error code can be failed PC board
Feb 01, 2013 | Rheem Tankless Hot Water Heater...
Help with error code
Before calling service technician, open following link for Rheem tankless troubleshooting resources including error codes and typical maintenance:
Mar 20, 2012 | Rheem Tankless Hot Water Heater...
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
Rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Rheem tankless shuts down on it's own.
Check to make sure wire is solid copper thermostat wire and not stranded
Aug 15, 2009 | Rheem Tankless Hot Water Heater...
I have c4 followed by 13 code.
code 13 is a lack of combustion air in the area, or poor combustion. try getting some more air in the room with a fan and see if it runs
Jul 05, 2009 | Rheem Tankless Hot Water Heater...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
103 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
