Question about Toshiba CX36F67 36" TV
I have a CF36F67 tv that has a black rectangle covering about 2/3rds of the bottom half of the screen. Going to a menu will get rid of it until I let the menu time out and then it comes back. I've unplugged it and tried everything else.
  • 902 Answers
Under menu check to see if you have it zoomed or aspect ratio is wrong. also check if its connected to the cable box if you have the right aspect ratio. othewrise you need to get your tv tube re-calibrated.
Posted on Mar 20, 2011
We have a black rectangle appearing on TV when playing DVDs and can't get rid of it. We were setting up to watch a DVD, pushed some buttons inadvertently on the remote and ended up with menus that we...
it sounds like someone turned on the text box on the closed caption feature on the set there may be a button on the remote or look in the set-up features in the main menu
Techman.
May 16, 2010 | Bose 3 2 1 GS Series II DVD Home...
Daewoo DTQ-27U4SC Display Problem
Sounds like your closed caption may be on and here is how to turn it off..
1. Press the menu button until you get to the "SPECIAL" menu.
2. Make sure that Closed Caption and CC on mute are both set to OFF.
This should make that black box go away...
Good Luck and please rate this solution...
Jan 06, 2010 | Daewoo DTQ-27U4SC 27" TV
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
Black rectangle on bottom half of screen
The "Caption" mode may be on and set to "Text". To fix press MENU button on the remote then use down arrow to select "Setup" and press ENTER. Select "Caption" and press ENTER. Select "Off" and press ENTER. Press MENU again to exit setup.
May 09, 2009 | Televison & Video
Black Rectangle on Bottom of Screen
It is your Closed Captioning malfunctioning. You can try and access the menu and turn the CC off but more times than not it is a malfunction that is unfixable.
Please remember to rate this solution.
Feb 13, 2009 | Curtis-Mathis CM27101S TV
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Large Black rectangle on bottom half of screen
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Jun 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Black rectangle blocking view
SOUNDS LIKE U HAVE THE CLOSED CAPTIONING ON, CHECK IN YOUR MENU AND TURN OFF
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
