Question about Samsung Dishwashers
How to fix code 9E from a dishwasher Samsung model DR77 Thanks
5 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: samsung dw model dmr78ahs/xac
Hello, Welcome to FixYa.
The 9E code as it pertains to your Samsung is as follows according to the Samsung service manual...
ERROR TYPE - Low water level detected.
OCCURING CONDITION - Occurs when low water level even after water supply resumes after low level is detected the 1st time.
POSSIBLE/EXPECTED CAUSES - a) Low level sensor defective. b) Low level sensor wire loose/not connected. c) Main PBA fault/defective ( main board )
Steps to resolve-check.
Check for foreign material in the floater of the Low Level Sensor.
- Check the voltage between both ends (pink and brown wires) of the Micro Switch.
When operating normally after water is supplied:
- Check only the Micro Switch.(Remove the connectors before checking.)
Lift the lever: Short
Lower the lever: Open
Results.
- Faulty: Replace the Low Level Sensor, Remove foreign material from the floater
- Normal: Replace the Main PBA assy.
If you don't think this is something within your scope of abilities please call an authorized Samsung service center in your area.
Let me know what you find and I'll be glad to help you in whatever manner I can. I do have a generic service manual for Samsung dishwashers ( essentially all the same as for components and repairs) but you'll need to provide an email address for me to send it via pdf attachment. Good luck.
Regards,
Macmarkus :)
Posted on Apr 19, 2011
SOURCE: Samsung DMR78 dishwasher makes a grinding noise at
June 12,2011... i think a lot of the issues regarding noise and cleaning issues are related to the water sensor assembly. Small white plastic device on left hand side of dishwasher when pulled out. we had this dishwasher 3 months, the upper plastic clips broke, then the loud grinding noise, - called for warranty repair, in meantime got a code 9E - low water level. Repair man came out, pushed some special sequence of buttons and it never gave him the history of the 9E code coming up, but we ran a cycle and sure enough it came up. Repair man came back 3 weeks later with parts (yes 3 weeks - upper brackets, water sensor assembly and a new bottom tray - as there was a thumping sound). Repair man found some plastic shavings in the water assembly which may have caused the fault in the sensor reading water level. dishwasher fixed, very quiet now, and dishes are super hot to touch after cycle and clean - if you place dinner plates apart - tines are too close.
prior to being fixed - dishes would have a few water dirt stains, and dishes were not completely dry. Now they are dry completely - even the plastic utensil holder handle. I also made sure the drain hose was fastened up high to top of inside cabinet. i still would not recommend this dishwasher - but want to help those of us who are stuck with it !! hopefully this helps.
Posted on Jun 13, 2011
mc1bean
  • 3053 Answers
SOURCE: samsung dishwasher model dmr77 runs for 3 mins
Hello, kurt
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
Samsung dishwasher code 9E
Internet search "Samsung dishwasher 9e error code". Many videos to watch to show you how to fix the problem yourself.
Sep 05, 2015 | Samsung DMT800RHS Dishwasher
I have a 3 year old Samsung DMT800RFS dishwasher. It had a 9E error, so we changed the part on the side and replaced the interior gasket. Now we get a oE error and I can not enter Service Mode to re
I don't know if this is the same. However, on my washing machine I had to clear out the water trap at the bottom of the machine. I know I have to clean it out every 6 months to be on the safe side. This also helps the machine to not smell like old stagnate water and helps your clothing smell fresher with not having that water build up and sit. I found all strange things in all kinds of water overflow tubs.
Dec 20, 2014 | Samsung Dishwashers
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
Samsung dmt800rhs errorcode 9e
http://www.youtube.com/watch?v=HXHRPd8VisE The water level float switch needs to be cleaned. There is a micro switch on the assembly don't get the switch wet. This video will show you what to do.
May 06, 2014 | Samsung DMT800RHS Dishwasher
9E error code on dmt800rhs dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
Samsung dishwasher model dmr77 runs for 3 mins then stops showing error code of 9e will not run full cycle
Hello, kurt
Aug 16, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My Samsung DMR57 Dishwasher gives me error code 9e, telling me its a low water level error. Anyone know what this is and how to fix it ?
    Aug 17, 2009 | Samsung DMR77LHS Tall Tub Dishwasher
    Dishwashers Logo
    128 people viewed this question
    Top Samsung Dishwashers Experts
    vince
    gbob59
    Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
