Question about NAD T752 Receiver
Upon starting the T752 it shuts itself down immediately the led is yellow so it didn't hit the breaker, have only 2 speakers hooked up have composite input from x-box 360 and digital input have DVD selected so it should pick up the composite input and i have optical 1 selected? i also changed wall plug connection and it still shuts down upon starting
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
Jun 27, 2012 | Apple Power Mac G5 Desktop
Unit self powers down.
ok! maybe you have lost contact at the PCB you can re solder the PCB thats why the oscillation is not working.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The Limit Prot LED on my RCF Art-321A speaker remains on upon power up. The speaker also pops upon powering down. What do you think it could be? Thanks
The amp is blown. Some popping on power down is NOT uncommon, but the protect LED means the pwer amp is out of balance which is ******* speakers. Take in for repair.
Aug 05, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
Genny won't shut down
your control board is most likely bad.
Jul 07, 2009 | RTO ASCO 165 Series 200A Automatic...
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Keeps shutting off
are you able to check whether any of your speakers may have been blown? or have a direct short to ground ..this usually indicated by the amplifier protecting itself and shutting down,, try un plugging one speaker at a time and you may find that it is one of the speakers ....then get a replacement or get it repaired
Jul 09, 2007 | Aiwa AV-D97 Receiver
Immediately shuts off when turn on.
get another speaher wire two wires are touching making ti go into protect mode..
Jan 15, 2007 | Onkyo HT510 Receiver
NAD T752 Receiver Logo
51 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
