SOURCE: Missing Turntable Piece
Here is a link to a parts supplier and you can pick and choose which components you want.. http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope this helps..
SOURCE: I like to know how
I would think this is addressed in your owner's manual.
If
for some reason you don't have your owner's manual, I would suggest
calling the dealer where you bought it to see if they have a number for Betty Crocker.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: my microwave stop working the clock and timer
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
SOURCE: I purchased a G E
The problem may be that the base is not turned all the way into the cup due to damage of the threads or the wrong gasket or having more then one gasket. This would keep the tabs from aligning with the notches in the base. Try the other base and cup and if that doesn't work then the notches may be the problem. There may be some foreign object jammed in them
or they may damaged. Take a small screwdriver and see that the spring loaded ramps in the notches compress. GE's cusomer assistance number is 1-877-207-0923. These units have a 2 year warranty though I dont know about second owners.
SOURCE: We have a KitchenAid built
I cannot determine from your description what part it is you exactly need.
This is a link to Sears Parts and you make and model
Look through the diagrams.
As for price and delivery... that's up to Sears
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-YKHMS1850SS0/0593/0123370?searchedModel=YKHMS1850SS&blt=
It is best to call the Customer Service number. From there they will ask for your name and addy. They can send you a copy.
Please call 1-800-446-1898 between (7:30 a.m. - 5:30 p.m. CT, weekdays).
Sincerely, olivr18754
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required.
The information is normally free of
charge.
I hope this helps.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies as required.
charge.
I hope this helps.
