Question about GPS
When I try to connect my blackberry to the via 160 via bluetooth it asks for a keycode that did not come with the pack. WHat is the keycode.
  • 368 Answers
Glad to HELP YOU!
Usually the pairing passkeys are four up to six digits.
\I'd suggest you to try
0000
or
1234
and in case the above mentioned will not work try to add another ZERO or (for the second row) another DIGIT.
GOOD LUCK!
Posted on Mar 20, 2011
I bought my son a blackberry curve 8250 a few days ago. I cannot send any files to his new phone via bluetooth, even though the phones do pair with each other. Please help!
When you send over bluetooth on a blackberry and the handset pairs you need to select the file type you are send and be in the folder to received. Once in that folder you need to click the blackberry key and select received via bluetooth.
Feb 19, 2011 | RIM BlackBerry Bold Smartphone
Tip
Bluetooth on 7290
just to help a lot of people out, the 7290 can ONLY use its bluetooth capabilities to connect to hands free headsets. i have had so many ask why it wont connect to pc via bluetooth or get ringtones from other phones.
sorry guys but without a firmware update thats the way it is.
on Sep 05, 2008 | RIM BlackBerry 7290
I have a blackberry storm and i activate my bluetooth but when i try to recieve something e.g. Music from another phone the other phone finds my bluetooth but it wont send? and when i go into manage...
Go to Media> Music>Send the Music from the phone>Press the Blackberry button on your phone>Then scroll down to Recieve File via Bluetooth.
Best regards
Jul 25, 2010 | RIM Research In Motion Blackberry Storm...
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Can send, but can NOT receive via bluetooth on BB 8110
I contacted the supplier and found out that the handset is faulty. As it was not a simple technical problem, they will exchange the handset- hopefully with a faultless one!
Thanks
Shast
Aug 28, 2009 | RIM Blackberry 8110 Cellular Phone
I have a Blackberry 8310. When I try to connect
go into bluetooth setup screen and hit options, make sure BB is set to discoverable. Then hit menu again and choose "add device".
Aug 21, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Is there any method to surf internet on Blackberry Pearl 8100
best method i feel is that you can connect it to the pc via a USB and can start surfing
via bluetooth also you can surf using your computer's internet connection but before that you may have to change the settings in the bluetooth configuration side to allow internet sharing to the other device
cheers
pls rate if it was any help
Jul 04, 2009 | RIM BlackBerry Pearl 8100
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
