Question about Kenmore Refrigerators
What makes a ref drops temp from 37 to 33 degrees
  • Kenmore Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Mar 20, 2011
I have a Dometic rm 2612 RV refrigerator the freezer freezes to 18 degrees the frig cools at nite hoewver durning the day it warms up tu 50 + degrees the freezer remains at 18 degrees. the out side temps...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Oct 02, 2011 | Refrigerators
A "woof, woof" sound after I heard the ice drop in
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 27, 2011 | Samsung RF267AE (25.8 cu. ft.) Bottom...
2007 french door -bottom freezer -kenmore elite fridge- freezing foods in fridge and icemaker not making ice regularly- sporatically making small amounts of ice cubes motherboard was replaced when fridge...
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 14, 2011 | Refrigerators
Refrigerator will not drop from 47 degrees to 37 degree setting. Freezer will no drop from 20 degrees to 0 setting. Ice maker not working.
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 12, 2011 | Refrigerators
GE Monogram ZIDS240PSS Double Drawer Refrigerator freezes items stored. Temp indicator as low as 19 degress F. Turned unit off and back on using touch pad. Touch pad instructions were ignored without...
Leo Ponder
imufo2
Sep 09, 2011 | GE Monogram ZIDS240PSS Double Drawer...
I vacuum the unit condenser about two weeks ago. Last night I noticed there is a constant humming noise and the freezer will not reach its preset temperature of zero degrees, ranging from 14 degrees to 8...
The cold control is the knob in the ref that turns it on and off and has numbers on it.
The cold control probably the culprit
If this doesn't work Do this
Leo Ponder
imufo2
Aug 13, 2011 | Sub-Zero 611 / O Bottom Freezer...
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
Will freezer work in low ambient temperature (i.e. 26'F)? I have a GE refrigerator/freezer (c. 1983) in a cabin which gets winter temps around 25 degrees. I found the freezer contents had melted and then...
The compressors are rated for ambient temp. and most refrigerator compressors are rated for abour 50 degrees F
to answere your question yes the ambient temp is a problem.
And as for the Thawing, the refrigerator will go into defrost every 8 to 10 hrs and turn on the heater inside the freezer for about 30 min.
You can also cause damage to the seal system and the compressor because the oil will become slugish inside the compressor.
In other resarch I found that because of the ambient temp the freon gas (mostly the newer freon's) won't work corectly because they stay in liqued form.
Jan 11, 2010 | Refrigerators
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
