Question about Brookstone Micro CD System CD Player
How do I change the clock on the 2.1 micro cd system? Usually I do it from my remote but it no longer will change the time.
Set time on sonymp3 cmt-bx20i
You need to use buttons on the remote to set the clock.
1.Turn on the system.
2.To select the clock set mode press TIMER MENU. If the current mode appears on the display, press up and/or down to select
"CLOCK SET?" and then press (+)
3.To set the time. Press up and/or down to set the hour, and then press (+) to confirm. Repeat to set minutes.
The clock needs to be re-set whenever power is lost to the unit.
The clock can be momentarily displayed when the system is off by pressing DISPLAY. The clock is then displayed for about 8
seconds.
The full support section with manual downloads is available here for further help and guidance:
http://esupport.sony.com/US/p/model-home.pl?mdl=CMTBX20I
Hope this is of help.
Dec 17, 2014 | Sony Vertical iPod micro system CMTLX20I...
CD Stero System Model SC-AK200 remote is not working. Therefore Clock cannot be set. Can clock be set manually? Is there any trick to re-initialising a remote when a new remote is used on the old system...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=SC-AK200+&uuid=A13101189236741
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 08, 2011 | Panasonic SC-AK200 CD Shelf System
I was given a Memorex CD Micro System (21 Channel) as a present. They no longer have their receipt. I have the box that it was purchased in, but there was no remote control enclosed. Everything works...
In regards to your issue, you can actually increase ordecrease the volume with the volume +/- buttons located on top-right section ofthe unit. If you really want to get a remote you can contact Fox Internationalwhich is the company that handles parts and accessories for Memorex Electronic products. In case they do not have the remoteavailable, there is another company that sells remotes for different products;their web site is www.remotes.com. I hopethis information was helpful.
Nov 18, 2010 | Memorex Dual Alarm Clock Radio for iPhone...
How to set the clock
with remote:
1 Switch on the power.
2 Press [CLOCK/TIMER] to select “CLOCK”. Every time you press the button: 3 (within 7 seconds or so) Press [g/REW/3] or [4/FF/f] to set the time. 4 Press [CLOCK/TIMER] to finish setting the time. The display will return to whatever was displayed before you set the time
Dec 24, 2009 | Panasonic SC-AK100 CD Shelf System
How to change my time on my clock without the remote
1.hold the source button until the unit turns off
2. then push and hold the audio or function button until the clock is displayed,
3. then use the updown left/right arrows to change the time.'
4. press source to exit
Aug 14, 2009 | Pioneer DEH-1900MP CD Player
Cannot set clock or timer
turn the system off and press the clock button on the remote after the clock illuminates hold the memory button on the remote until the hour starts to blink then press the preset up or down to change ( go through 12 hours to change AM PM) then press memory to get to the minutes after setting the minutes press memory to save
Mar 11, 2009 | Sharp XL-1700 CD Shelf System
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
Setting the clock on a Philips MCB240
hi
will this help
a user guide download and search the clock settings hopefully this will solve it .
PHILIPS MCB240 Micro Hi-Fi
riz.
Feb 26, 2008 | Audio Players & Recorders
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
27 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Marvin
Marvin
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
