Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Mode dial hello, i dropped my camera and the button to press to take a picture is no longer there. where can i find a replacement and is it easy to replace it? thanks! belinda
    Master:
    Sergeant:
  • 398 Answers
Contact customer support be sure to have serial number available I am sorry to say that digital camera repair is mostly not available on most point and shoot models. Once warranty expires we are just about stuck.
Posted on Aug 02, 2008
HOW TO TURN ON FLASH
Flash should pop up automatically when you operate camera in easy mode (green square on dial selector) in low light conditions. If using in manual modes press the button on the left side of the lens mount. To fire the flash without taking a picture press the button used to zoom out when viewing pictures.
If your flash does not work at all then there is probably a fault with the charging circuit or firing circuit.
May 11, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
How do i change the date stamp on my camera? Kodak Easy Share m1093
  • Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
  • 2
    Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
  • 3
    Press the "Down" button to change the selection to "None." This removes the date stamp.
  • 4
    Press "OK" to save the setting. Press "Program" to return to capture mode.
  • Oct 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
    How to activate flash in my camera? please tell me step by step.
    First you can select a desired camera mode by using the Mode dial on the top of the camera. Below picture is Mode selector.
    7bec22b.jpg Simply first press flash button which is shown in the fugure below.
    Press a few times to the flash button. So that you set the desired flash position. Positions are shown below.
    6b66403.jpg Now you can take a picture.
    Mar 01, 2010 | Samsung S760 Digital Camera
    How do you find and use the self-timer setting?
    Hello.
    Turn the function dial to the drive mode position.
    Press the function button in the center of the dial.
    Turn the front control dial to select the self-timer drive mode.
    Use the rear control dial to to switch between a ten-second and a two-second delay.
    Press the shutter-release button partway down or press the function button to set the mode.
    When you are ready to take the picture.
    Press the shutter button partway down to set the focus and exposure.
    Press the shutter button all the way down to start the timer.
    Hope this helps.
    Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
    Wont take photos outside
    The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
    If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
    But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
    Feb 29, 2008 | Canon PowerShot A400 Digital Camera
    1. Mode Dial not working, "Take-Picture-Button" not working.
    If the camera was dropped, then it's really causing those kinds of issues like mode dial and shutter button will not work.
    But you could still try these steps below:
    First, do the POWER RESET:
    - Turn off camera
    - Remove batteries for a minute
    - Reload batteries
    - Turn on camera
    Second, do the MASTER RESET
    - Press on MENU button
    - Press on the right button until you see SETUP 2
    - Scroll down until you see RESET
    - Press the right button to pick up on YES or NO
    - Press on OK/MENU button for changes to be saved - Turn off camera for a few seconds so that settings will be refreshed
    Third, if it still does the same thing, then your camera needs to be repaired by a technician.
    If you want to know where you could send it, just call the hotline of the manufacturer of your product so you could get assistance
    about this matter.
    Jan 01, 2008 | Samsung Digimax S630 Digital Camera
    The Flash on my camera won't work
    When taking pictures, you must really be allowing time for the camera's flash to be charged
    before you could take another picture so that camera will have enough time to rest and it
    could function normally.
    But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
    You could still try these steps below:
    - Turn off camera
    - Reload batteries
    - Turn on camera
    - Be in AUTO mode
    Turn it on and take a picture.
    When you want to have just the AUTO FLASH.
    - Rotate the mode dial to PROGRAM
    - Press the LEFT/FLASH button until you've seen the
    LIGHTNING icon with the Letter A on the leftmost part of the screen
    - Try to take a picture by pressing and holding the shutter button
    halfway first for 3-5 seconds and then press it all the way down
    Dec 13, 2007 | Samsung Digimax S630 Digital Camera
    In AUTO mode, pictures are all dark!
    Yes you definitely can,
    Turn on the camera.
    The mode dial can be turned to any setting.
    2. Press the button for longer than 5
    seconds.
    The message “Reset settings to default?” appears on the
    LCD monitor.
    3. Select [OK] using the left and right
    buttons, then press the button.
    The normal screen resumes when resetting is complete.
    To cancel resetting, select [Cancel] instead of [OK].
    Dec 09, 2007 | Canon PowerShot A70 Digital Camera
    Review the pictures
    Using the Quick View Button Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
    Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
    Review the pictures
    Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
    Canon PowerShot S410 / IXUS 430 Digital Camera Logo
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
