Question about Reizen Atomic Talking Clock
I, too, cannot reset my mother's Reizen talking atomic clock to show the correct time for Daylight Saving Time. I reset the clock to the correct time, it "confirms" it and the hands move to the confirmed time, but overnight it readjusts itself to lose the hour I had advanced. I am in the Eastern Time Zone; if it were possible to set the clock to Atlantic Time, I would, which would allow for the extra hour, but the clock only has programming for Eastern, Central, Mountain and Pacific Time. If it is truly synchronized with a master clock somewhere in Colorado (which I believe the instruction manual had stated), why cannot the clock adjust itself to DST? My cell phones and computers had no problem, even with the earlier start date for DST this year. Help, please?
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
I lost the instructions for the talking Reizen atomic clock and both of them are now an hour off. How do I reset the time?
You need to change the 'Zone' settings on both; the signal from Boulder, CO can't tell where you are, you have to make the correction locally and then they will track the signal accurately as long as they can receive it.
Nov 27, 2011 | Reizen Atomic Talking Clock
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
How do I set my skyscan atomic clock
You don't. Just make sure that the rear switches are set for the correct time zone, and that the DST switch is set to the ON position (unless you're in an area that does not use Daylight Saving Time). Make sure that your batteries are fresh, and situate the clock so that the front (or back) is facing roughly in the direction of Ft. Collins, Colorado. Give it a couple of hours to find and sync with the time signal, and it will set itself.
Bill B
Jul 02, 2010 | SkyScan 86709 Atomic Wall Clock
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
SkyScan 87801 how to reset time
Keep pushing the set button until dst shows on the date window then see the clock window it will read on or off press the + button for on or off.
Sep 15, 2008 | SkyScan 86709 Atomic Wall Clock
Atomic clock
There is a setting on the clock to turn on "DST"- daylight savings time feature. You have to push the set button on the back of the clock repeatedly until you see "DST" blinking. You should also see "OFF" blinking at that point indicating that the feature if turned off. If you now push "+" button on the back of the clock once it should show "ON" blinking instead of "OFF". Hope this helps.
FixerUpper
Nov 04, 2007 | SkyScan 86709 Atomic Wall Clock
Daylight savings time
so long as the US atomic clock adjusts their daylight saving times then you should be fine check this link for some more details (about the scr 110 but seems to be basically the same) http://www.amazon.com/H-H-Scott-SCR110-Atomic-Clock/dp/B00004TZDN/ref=sr_1_2/104-1966292-9407907?ie=UTF8&s=electronics&qid=1173502881&sr=1-2 hope this helps :)
Mar 10, 2007 | H.H. Scott SCR120 Clock Radio
Reizen Atomic Talking Clock Logo
Top Reizen Measuring Tools & Sensors Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Reizen Measuring Tool and Sensor Expert? Answer questions, earn points and help others
